Serial Connection
I want to connect tow Arduino Board By Serial (uart)
The Question Is: What is The Max Cable Length can i use To Connect The Boards Together By Serial (Uart)?
alloushi987:
Why don't you tell us what length you want to use? There are many factors that influence length. Baud rate, Shielding, Interference, to name a few.
Pretty darn long with the right buffer:
"RS-485 transmits digital information between multiple locations. Data rates can be up to, and sometimes
greater than, 10Mbps. RS-485 is designed to transmit this information over significant lengths, and 1000
meters are well within its capability. The distance and the data rate with which RS-485 can be
successfully used depend a great deal on the wiring of the system."
MAXIM AN763 Guidelines for RS485 wiring.pdf (247 KB)
i want cable length about 100 Meter
