Hello all,
I'm using an AI code generator to finish a project. I'm trying to send text from a PC running Blender through the serial port to launch a sketch on my Arduino Uno R3. Right now I'm just trying to get it to blink a few LEDs for a few seconds.
The Code generator wants me to include Serial.h but I can't find that library and what I'm seeing is that the Serial.h library is included in the Arduino firmware?
Thanks for any help I can get.
Here's the code:
// Include the Serial library
#include <Serial.h>
// Define the pins for the LEDs
#define LED1 11
#define LED2 12
#define LED3 13
// Define the interval for the LEDs to flash
#define INTERVAL 2000 // 2 seconds
// Define the duration for the LEDs to flash
#define DURATION 8000 // 8 seconds
// Initialize the serial communication
// Wait for the 'start' command to be received
while(!Serial.available()){}
// Read the incoming data
String command = Serial.readString();
// Check if the command is 'start'
if(command == "start"){
// Set the LED pins as output
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
// Loop for the duration of the flashing
for(int i = 0; i < DURATION/INTERVAL; i++){
// Turn on the LEDs
digitalWrite(LED1, HIGH);
digitalWrite(LED2, HIGH);
digitalWrite(LED3, HIGH);
// Wait for the interval
delay(INTERVAL);
// Turn off the LEDs
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
delay(INTERVAL);
// If the command is not 'start', print an error message
else{
Serial.println("Invalid command. Please send 'start' to begin flashing LEDs.");
And here's the poster child of why using AI to do something you don't know how to do yourself is a total waste of time.
Your AI is lying to you. It made stuff up. It gave you a confident sounding answer that is utter crap. There is no Serial.h to include. Feel free to look through the Arduino AVR core. There's no such file.
Also, as @bobcousins already pointed out, that isn't a valid sketch in any way, shape or form anyhow. Anyone with the utterly basic skills to make an Arduino blink an LED should have recognized that immediately.
#define LED1 11
#define LED2 12
#define LED3 13
while (!Serial.available()) {}
if (Serial.available())
if (command.substring(0, 5) == "start")
for (int i = 0; i < DURATION / INTERVAL; i++)
// Turn on the LEDs
delay(INTERVAL);
delay(INTERVAL);
The prompt was something like:
Arduino Uno R3
3 LEDs on pins 11, 12 and 13
Blink for 2 seconds and stop after 8 seconds when the command "start" is sent through the USB
