serial interface between uno+nodemcu ,reading data
hello,
I interfaced the arduino uno with esp8266 nodemcu, and triying to read data from esp8266 which received data from arduino uno .
I want to read those data from Esp8266 and process it for next further process ,but unable to trad those data which i receive through Softwareserial.h RX ,TX
my code is like this,
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX | TX
#include <DHT.h>
#define DHTPIN 6                           //Pin D1
#define DHTTYPE DHT11
int incomingByte = 0;
DHT dht(DHTPIN, DHTTYPE);
char c = ' ';
mySerial.begin(115200);
 dht.begin();
  while (!Serial) {
  Serial.println("hi esp");
  float h = dht.readHumidity();
  Serial.println(h);
  float t = dht.readTemperature();
  Serial.println(t);
if (mySerial.available())
mySerial.write('t');
mySerial.write('h');
I change all data pattern like hex ,binary decimal but it hasn't worked.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable.
You can send data in a compatible format with code like this
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
...R
thanks for reply ,
but i still not understood it that how to recognise the data receive by the node mcu.
i just want to read the temperature data for arduino uno and receive by nodemcu to process further for task.
In order to do that what can I change in program for receive data from uno .....
pin connection are like these,
arduino uno pin 3 as TX - RX of nodemcu
arduino uno pin 3 as RX -TX of nodemcu
arduino uno pin Gnd - Gnd of nodemcu
arduino uno pin 3.3 - 3.3 of nodemcu
my nodemcu code arel like these......
#include <ESP8266WebServer.h>
#include <ESP8266WiFi.h>
const char* ssid = "Vaahaka@321";
const char* password = "vaahaka@22018";
SoftwareSerial mySerial(13, 15);
IPAddress staticIP (192, 168, 1, 22);
IPAddress gateway (192, 168, 1, 9);
IPAddress subnet (255, 255, 255, 0);
  Serial.begin(57600);
  pinMode(4, OUTPUT);
  Serial.println("Server started");
  WiFi.begin(ssid, password);
  WiFi.config(staticIP, gateway, subnet);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(t);
  Serial.println(h);
so,what can i change in code to receive those data on nodemcu..............
Software serial may not work well for that high of baud rate.
Implement robin's code at the receiver side. Write complementing code for the transmitter
Based on his example 3 / 5, the basics of the transmitter:
1)
Print '<'
2)
Print temperature
3)
Print comma
4)
Print humidity
5)
Print '>'.
Start with SoftwareSerial working at 9600 baud. When you get everything working try a higher baud rate. I believe it should work at 38400 baud.
...R
