I am seeing a COM3 port active in Tools->Ports and I can open Serial Monitor at COM3. Unfortunately nothing is printed in Serial Monitor. On examining the upload, however I found upload is taking place in COM6. I have Windows 10 laptop and Arduino Nano 33 IOT. I am having this problem very recently. The board was working perfectly fine earlier. Please help.
Below is the relevant part of upload log.
Sketch uses 28620 bytes (10%) of program storage space. Maximum is 262144 bytes.
Global variables use 4348 bytes (13%) of dynamic memory, leaving 28420 bytes for local variables. Maximum is 32768 bytes.
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {} => {}
PORTS {} / {COM6, } => {COM6, }
Found upload port: COM6
C:\Users\abcd\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM6 -U true -i -e -w -v C:\Users\abcd\AppData\Local\Temp\arduino_build_70678/bmp280test.ino.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Apr 19 2019 14:38:48
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Apr 19 2019 14:38:48
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.855 seconds
Write 28628 bytes to flash (448 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[==== ] 14% (64/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[======== ] 28% (128/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[============ ] 42% (192/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x1000)
[================= ] 57% (256/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x6000, size=0x1000)
[===================== ] 71% (320/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x7000, size=0x1000)
[========================= ] 85% (384/448 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x8000, size=0x1000)
[==============================] 100% (448/448 pages)
done in 0.226 seconds
Verify 28628 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = eb75
checksumBuffer(start_addr=0x3000, size=0x1000) = c73d
checksumBuffer(start_addr=0x4000, size=0x1000) = 215d
checksumBuffer(start_addr=0x5000, size=0x1000) = 98fa
checksumBuffer(start_addr=0x6000, size=0x1000) = b29c
checksumBuffer(start_addr=0x7000, size=0x1000) = 7257
checksumBuffer(start_addr=0x8000, size=0xfd4) = 36af
Verify successful
done in 0.023 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
