Hi, I'm facing a problem where the serial monitor is blank, no result. Pretty sure the coding and setting is correct.
Hardware
Arduino Uno
Moisture sensor
Arduino setting
Board "Arduino Uno"
Port "COM5 Arduino Uno"
Baud 9600
**Code **
i get the code from a website. supposedly it can work, however, on my serial monitor is blank, won't show any result.
int msensor = A1; // moisture sensor is connected with the analog pin A1 of the Arduino
int msvalue = 0; // moisture sensor value
int led = 13;
boolean flag = false;
pinMode(msensor, INPUT);
pinMode(led, OUTPUT);
msvalue = analogRead(msensor);
Serial.println(msvalue);
if ( (msvalue >= 500 ) && ( flag == false ) )
digitalWrite(led, HIGH);
flag = true;
if ( (msvalue <= 300 ) && ( flag == true ) )
digitalWrite(led, LOW);
flag = false;
