Serial Monitor is not recognising Bluetooth connection
I am working on a project which involves a bluetooth connection. I am using a HC-05 connected to my laptop which is an HP. The connection between the laptop and HC-05 is fine, at least thats what the lights on the bluetooth module says. However, my Serial monitor is not recognising anything in COM5, the port that the bluetooth module function off of. I have tried the other COM ports with no avail and all I am doing is trying to test the bluetooth module with a code that simply turns an LED on when given 1 and off when 0.
Welcome to the forum
Please do not post pictures of code or Serial monitor output
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Your topic has been moved to the Programming category of the forum
