Serial Monitor printing - Please help me with this beginner sketch
I'm a beginner, I have this problem while playing around with Serial Monitor
If I disable line 27 only, then line 28 printed normally and vice versa.
But when I activate both line 27 & 28, they didn't work, the Serial Monitor printed NOTHING!
I couldn't figure why, is that just me or a serial printing problem? Would you help me to make both line work?
// board: Arduino UNO R3
//the schematic is simple: only a potentiometer connect to 5V, GND, and A0
int potPin = A0;
int read_Value;
const int num = 10;
int index = -1; // -1 because it will be increased by 1 in the first loop
                // it will never be -1 again in any next loop
int array1[num];// so there is 11 variable, index from 0 to 10
  for (int i = 0; i<= num; i+=1) {
    array1[i] = 1;
  if ( index >= num) {
    index = 0;
    index += 1;
  read_Value = analogRead(potPin);
  Serial.println(read_Value);  // Line 27
  Serial.println(array1[index]); // Line 28
  delay(100);
Post your code in your original post in tags
If an array has 10 elements, they are indexed 0 through 9. Write beyond that and you're messing with memory you don't own. Results will be undefined.
As indicated by gfvalvo.
And this comment is incorrect
There are 10 variables, index from 0 to 9.
The little change you need to make in your sketch is this: for (int i = 0; i < num; i += 1) in order to get print out on your Serial Monitor. The reason has been explained in Post#2.
Also, as you are PRE-incrementing, the index this code needs to change or you’ll be reading one element past the end as well...
 if ( index >= num - 1) {
    index = 0;
    index += 1;
TBH you’d be far better POST-incrementing. It’s easier to handle...
int potPin = A0;
int read_Value;
const int max_index = 10;
int index = 0;
int array1[max_index];// so there are 10 variables, index from 0 to 9
  for (int i = 0; i < max_index; i++) {
    array1[i] = 1;
  index++;
  if (index >= max_index) index = 0;
  delay(100);
