The Serial Monitor shows only bullshit
What baud rate have you got in Serial.begin() in the sketch ?
9600
Please post a complete sketch that illustrates the problem, not a picture of part of it. Which Arduino board are you using ?
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
macOS Monterey 12.1
Board is Arduino UNO Wifi Rev2
The code is CheckFirmwareVersion.ino from Files>Examples>WIFININA>Tools
* This example checks if the firmware loaded on the NINA module
* is updated.
* Circuit:
* - Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and UNO WiFi Rev.2)
* Created 17 October 2018 by Riccardo Rosario Rizzo
* This code is in the public domain.
#include <SPI.h>
#include <WiFiNINA.h>
// Initialize serial
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Print a welcome message
Serial.println("WiFiNINA firmware check.");
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// Print firmware version on the module
String fv = WiFi.firmwareVersion();
String latestFv;
Serial.print("Firmware version installed: ");
Serial.println(fv);
latestFv = WIFI_FIRMWARE_LATEST_VERSION;
// Print required firmware version
Serial.print("Latest firmware version available : ");
Serial.println(latestFv);
// Check if the latest version is installed
if (fv >= latestFv) {
Serial.println("Check result: PASSED");
Serial.println("Check result: NOT PASSED");
Serial.println(" - The firmware version on the module does not match the");
Serial.println(" version required by the library, you may experience");
Serial.println(" issues or failures.");
// do nothing
Does the code produce the required output using the classic IDE ?
I have the classic IDE not installed. But on PlatformIO the serial monitor output is ok.
I don't have this board so I can't test the code fully
After restart the IDE the serial monitor works for a while. But after a minute this happens again. I think it is a general problem.
