Serial Monitor will not connect or change baud rate
CLI Daemon Offline is back this morning...
Terrypin,
My Bad, went to the com4 window, checked the driver, it is for CH340
Yet the problem persists...
as noted, I am new to this, I attempted to upload an image showing the com4 window... not sure it worked
Here is a screen shot of my IDE window
Showing baud rate set at 9600 in sketch and 9600 in Serial Monitor, able to get drop down of baud rate, yet not able to change the rate.
Right. Sorry. I assumed.
So read up on how to change to the old version of CH340 that I showed earlier, dated 18/01/22.
Was the problem present in Arduino IDE during the session from which you collected that output?
I ask because I can see from the output you shared that Arduino IDE is communicating with the "CLI daemon" (this is referring to a helper tool named Arduino CLI) as expected.
The output you shared doesn't contain anything that indicates a problem which would cause the symptoms you are reporting.
ptillish,
Yes, the problem was, and still is there.
CLI Daemon has been a hit and miss since this morning. After booting to safe mode, uninstall and reinstall of IDE CLI Daemon has worked intermitantly (it was suggested that anti-virus software could have interfered in the installation process).
The Serial Monitor communication has not been established yet.
Just tried rolling back the driver in com4 as per CH340 Driver Fix Installation and no success with that.
Have found in other forum threads and from suggestion here from Terrypin, the driver date can cause issues, meaning the older drivers work for some.
Have not found the 18/01/22 driver Terrypin suggested, however did find one from 2019... that did not work for the board I have had connected attempting to run Serial Monitor. Found anther thread that talked about the CH340 chip having or not having the number embossed on the chip. One of my boards has an embossed chip, the other does not. The un-embossed chip is the one that has been connected, was able to roll back the driver with that one. Connected the embossed chip board, same issue, attempted to change driver (no roll back option with that board) and windows will not allow driver to be changed.
And all the while, the base problem exists... "Not Connected. Select Board And Port To Connect Automatically."
Tried this trick also... no help
WELL! WHAT DO YOU KNOW!
Installed IDE 1.8.18 and Serial Monitor works!!!
So, exactly WHAT is up with IDE 2.3.6???
IDE 2.3.4 performed the same as IDE 2.3.6
IDE 2.1.1 & IDE 2.0.1 fail to launch, even after 30 minutes.
IDE 1.8.18 launches within 10 seconds, automatically detects board and COM port, loads sketch quickly, and runs sketch with Serial Monitor as desired.
Could this be due to my PC being 9 years old?
Not sure of the release dates of the 2.x.x IDEs...
I run a 2007 Linux Mint 64 bit and 2023 win11 which are not fast, but work.
I do need to let them do their thing on fresh installs or updates, which usually include system reboots.
Do any of the four 2.x ‘related’ threads below offer any clue?
So, with that, it would not likely be that my PC is not compatible. Or the fact that I am running Win10, as opposed to win11 could be an issue?
I would stick with 1.8 on old PCs and old OSs. Leave 2.x for new PCs and OSs.
The old and new IDE spend a lot of time updating libraries over the internet at least every restart of the IDE. A missing or unstable internet connection will slow or stop movement on the IDE. I restart the IDE and let it take the time it needs to update when I am away. Recently, the IDE decided to remove all the toolbar labels (file, sketch, tools, help). I stopped the IDE, got a doughnut and coffee, restarted the IDE, finished the coffee and doughnut, and all was well again.
I use Linux on my oldest PCs because the OS works, and the IDE is in "blob" form, so there is no installation, just run the blob.
These are just my "user" answers as I accept the IDE. The real answers will need to come from superusers and admin.
These two statements are somewhat contradictory.
My motivation for requesting the command line output was to try to get a clue about why Arduino IDE is in this "CLI Daemon Offline" state (which is surely the cause of the Serial Monitor problem. For this reason, it is essential to collect the output from an Arduino IDE session during which it was in that "CLI Daemon Offline" state.
Since you are encountering the "CLI Daemon Offline" state only intermittently, I don't think it is a problem with the installation (since such problems should produce the state consistently). However, it certainly could be caused by interference from your antivirus.
As I mentioned in my previous reply. The "CLI Daemon" is a separate helper tool named Arduino CLI that provides much of the non-GUI functionality of Arduino IDE under the hood (including communication between Serial Monitor and the board). Arduino IDE communicates with Arduino CLI via your computer's internal network ("localhost"). The "CLI Daemon Offline" message means Arduino IDE lost the network connection to Arduino CLI. This is not something that should happen under any normal conditions. It could happen if Arduino CLI crashed or hung. It could also happen if the communication between the two applications was somehow being blocked.
Unlike the modular approach used by Arduino IDE 2.x, the Arduino IDE 1.x Serial Monitor is solely implemented in the Arduino IDE application, without any reliance on the internal network. So it is not surprising that the behavior of the two IDE versions is different in this specific aspect.
Thank you for your input, it makes sense to me. Tried Linux some 8 years ago, was not able to get a good system function from it. Perhaps, once I get a newer PC to run Win11, I might experiment with running Linux again with this machine.
While the CLI Daemon was connected, I still had the Serial Monitor issue.
If you like, I re-ran the Command Line Output.
![image|690x341](upload://jGxsgl68qDi4LAGcUnpyHFTLHIq.png)
Is it possible that this is due to an older machine or that I am running Win10? Please excuse my newbee questions, only trying to understand this.
PS C:\Users\billh\AppData\Local\Programs\arduino-ide> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 31040
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/billh/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-07-16T18:10:03.512Z root INFO Backend Object.initialize: 5.9 ms [Finished 0.712 s after backend start]
2025-07-16T18:10:03.514Z root INFO Backend Object.configure: 4.9 ms [Finished 0.713 s after backend start]
2025-07-16T18:10:03.514Z root INFO Backend s.onStart: 2.7 ms [Finished 0.713 s after backend start]
2025-07-16T18:10:03.515Z root INFO Backend s.configure: 0.4 ms [Finished 0.752 s after backend start]
2025-07-16T18:10:03.516Z root INFO Backend d.onStart: 0.3 ms [Finished 0.752 s after backend start]
2025-07-16T18:10:03.517Z root INFO Backend d.configure: 0.2 ms [Finished 0.752 s after backend start]
2025-07-16T18:10:03.518Z root INFO Backend d.initialize: 39.5 ms [Finished 0.753 s after backend start]
2025-07-16T18:10:03.518Z root INFO Backend c.onStart: 0.3 ms [Finished 0.753 s after backend start]
2025-07-16T18:10:03.519Z root INFO Backend a.configure: 1.9 ms [Finished 0.755 s after backend start]
2025-07-16T18:10:03.522Z config INFO >>> Initializing CLI configuration...
2025-07-16T18:10:03.522Z root INFO Backend c.initialize: 0.8 ms [Finished 0.755 s after backend start]
2025-07-16T18:10:03.522Z root INFO Backend x.onStart: 1.2 ms [Finished 0.756 s after backend start]
2025-07-16T18:10:03.523Z config INFO Loading CLI configuration from c:\Users\billh\.arduinoIDE\arduino-cli.yaml...
2025-07-16T18:10:03.524Z daemon INFO Starting daemon from C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2025-07-16T18:10:03.524Z root INFO Backend a.initialize: 0.6 ms [Finished 0.757 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend w.onStart: 1.8 ms [Finished 0.759 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend r.configure: 2.8 ms [Finished 0.759 s after backend start]
2025-07-16T18:10:03.524Z discovery-log INFO start
2025-07-16T18:10:03.524Z discovery-log INFO start new deferred
2025-07-16T18:10:03.524Z root INFO Backend d.initialize: 0.7 ms [Finished 0.760 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend y.onStart: 3.1 ms [Finished 0.762 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend r.configure: 2.7 ms [Finished 0.762 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend a.onStart: 0.7 ms [Finished 0.764 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend h.configure: 0.6 ms [Finished 0.764 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend s.configure: 0.2 ms [Finished 0.765 s after backend start]
2025-07-16T18:10:03.524Z root INFO Backend l.configure: 0.2 ms [Finished 0.765 s after backend start]
2025-07-16T18:10:03.530Z root INFO Theia app listening on http://127.0.0.1:55799.
2025-07-16T18:10:03.530Z root INFO Finished starting backend application: 6.4 ms [Finished 0.771 s after backend start]
2025-07-16T18:10:03.531Z root WARN The local plugin referenced by local-dir:/c%3A/Users/billh/.arduinoIDE/plugins does not exist.
2025-07-16T18:10:03.532Z root WARN The local plugin referenced by local-dir:/c%3A/Users/billh/.arduinoIDE/extensions does not exist.
2025-07-16T18:10:03.532Z root WARN The local plugin referenced by local-dir:C:\Users\billh\.arduinoIDE\plugins does not exist.
2025-07-16T18:10:11.162Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-07-16T18:10:11.162Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-07-16T18:10:13.241Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\billh\\OneDrive\\Documents\\Arduino","data":"C:\\Users\\billh\\AppData\\Local\\Arduino15"}}
2025-07-16T18:10:13.241Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\billh\\OneDrive\\Documents\\Arduino","data":"C:\\Users\\billh\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-07-16T18:10:13.241Z config INFO Loaded the CLI configuration.
2025-07-16T18:10:13.255Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/billh/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/billh/OneDrive/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-07-16T18:10:13.255Z config INFO Validating the CLI configuration...
2025-07-16T18:10:13.256Z config INFO The CLI config is valid.
2025-07-16T18:10:13.256Z config INFO <<< Initialized the CLI configuration.
2025-07-16T18:10:13.296Z root INFO Resolve plugins list: 9773.2 ms [Finished 10.536 s after backend start]
2025-07-16T18:10:13.418Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="arduino-cli version 1.1.1"
time="2025-07-16T11:10:13-07:00" level=info msg="Using config file: c:\\Users\\billh\\.arduinoIDE\\arduino-cli.yaml"
time="2025-07-16T11:10:13-07:00" level=info msg="Executing `arduino-cli daemon`"
2025-07-16T18:10:13.479Z daemon INFO Daemon is now listening on 127.0.0.1:55809
{"IP":"127.0.0.1","Port":"55809"}
2025-07-16T18:10:13.479Z daemon INFO Daemon is running.
2025-07-16T18:10:13.647Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="Checking signature" index="C:\\Users\\billh\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\billh\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2025-07-16T11:10:13-07:00" level=info msg="Loading hardware from: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages"
time="2025-07-16T11:10:13-07:00" level=info msg="Loading package arduino from: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2025-07-16T11:10:13-07:00" level=info msg="Missing signature file" index="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2025-07-16T11:10:13-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2025-07-16T18:10:13.672Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="Missing signature file" index="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
time="2025-07-16T11:10:13-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-07-16T11:10:13-07:00" level=info msg="Loading tools from dir: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2025-07-16T18:10:13.680Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="Loading package builtin from: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-07-16T11:10:13-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-07-16T11:10:13-07:00" level=info msg="Loading tools from dir: C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2025-07-16T11:10:13-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
2025-07-16T18:10:13.724Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" isSingleLibrary=false location=platform
2025-07-16T18:10:13.733Z daemon INFO time="2025-07-16T11:10:13-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2025-07-16T11:10:13-07:00" level=info msg="Loading libraries index file" index="C:\\Users\\billh\\AppData\\Local\\Arduino15\\library_index.json"
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-07-16T18:10:21.380Z daemon INFO time="2025-07-16T11:10:14-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-07-16T11:10:14-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-07-16T18:10:21.384Z discovery-log INFO start resolved watching
2025-07-16T18:10:21.744Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 7281.4 ms [Finished 17.615 s after frontend start]
2025-07-16T18:10:21.744Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-07-16T18:10:21.769Z root INFO Deploy plugins list: 9773.2 ms [Finished 19.010 s after backend start]
2025-07-16T18:10:22.169Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 254.5 ms [Finished 18.084 s after frontend start]
Checking for update
Found version 2.3.6 (url: arduino-ide_2.3.6_Windows_64bit.exe)
2025-07-16T18:10:32.003Z root INFO Start frontend contributions: 7930.0 ms [Finished 18.151 s after frontend start]
2025-07-16T18:10:32.003Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-07-16T18:10:32.003Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-07-16T18:10:32.003Z root INFO >>> Restoring the layout state...
2025-07-16T18:10:32.003Z root INFO <<< Nothing to restore.
2025-07-16T18:10:32.004Z root INFO Initialize the workbench layout: 33.1 ms [Finished 18.232 s after frontend start]
2025-07-16T18:10:32.004Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-07-16T18:10:32.005Z root INFO Replace loading indicator with ready workbench UI (animation): 848.6 ms [Finished 19.113 s after frontend start]
2025-07-16T18:10:32.005Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-07-16T18:10:32.005Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-07-16T18:10:32.012Z root INFO Frontend application start: 7606.8 ms [Finished 26.490 s after backend start]
2025-07-16T18:10:32.019Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Waiting for backend deployment: 7061.2 ms [Finished 25.202 s after frontend start]
2025-07-16T18:10:32.071Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2025-07-16T18:10:32.071Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960) starting instance
2025-07-16T18:10:33.387Z root ERROR ---- !!!SLOW!!! DURATION: search took 1384.498 ms. Args: [{"type":"Updatable"}] ----
2025-07-16T18:10:33.617Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Sync of 23 plugins: 4334.6 ms [Finished 29.537 s after frontend start]
2025-07-16T18:10:33.619Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Loading plugin contributions
2025-07-16T18:10:33.619Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Load contributions of 23 plugins: 25.1 ms [Finished 29.562 s after frontend start]
2025-07-16T18:10:33.640Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-07-16T18:10:33.640Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-07-16T18:10:34.356Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-07-16T18:10:34.357Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2025-07-16T18:10:34.357Z root ERROR [hosted-plugin: 29960] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-07-16T18:10:34.381Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): PluginManagerExtImpl/init()
2025-07-16T18:10:34.385Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-arduino-api@0.1.2 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.472Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(cortex-debug@1.5.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.472Z root INFO [hosted-plugin: 29960] Debugger contribution has been registered: cortex-debug
2025-07-16T18:10:34.474Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-arduino-tools@0.1.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.476Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(cpp@1.52.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.478Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(json@1.46.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.480Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(json-language-features@1.46.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.482Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.484Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.485Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-de@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.487Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-es@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.488Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.489Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.490Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-it@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.491Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.492Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.493Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.494Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.495Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.496Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.496Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.497Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.498Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.499Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:10:34.505Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-07-16T18:10:34.512Z root INFO [hosted-plugin: 29960] calling activation function on Arduino IDE API for VS Code extensions
2025-07-16T18:10:34.515Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2025-07-16T18:10:34.551Z root INFO [hosted-plugin: 29960] calling activation function on JSON Language Features (built-in)
2025-07-16T18:10:41.025Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Starting plugins.
2025-07-16T18:10:41.051Z root INFO [hosted-plugin: 29960] PLUGIN_HOST(29960): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-07-16T18:10:41.095Z root INFO [hosted-plugin: 29960] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-07-16T18:10:41.096Z root INFO [hosted-plugin: 29960] calling activation function on Cortex-Debug
2025-07-16T18:10:41.104Z root INFO [hosted-plugin: 29960] GDB server console created
2025-07-16T18:10:41.112Z root INFO [f88ce535-2b8a-4bbb-8689-830e92321cb0] Start of 23 plugins: 7479.5 ms [Finished 37.058 s after frontend start]
2025-07-16T18:11:03.239Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 429.9 ms [Finished 8.289 s after frontend start]
2025-07-16T18:11:03.253Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-07-16T18:11:12.740Z root INFO Start frontend contributions: 726.6 ms [Finished 8.509 s after frontend start]
2025-07-16T18:11:12.740Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-07-16T18:11:12.740Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-07-16T18:11:12.740Z root INFO >>> Restoring the layout state...
2025-07-16T18:11:12.740Z root INFO <<< Nothing to restore.
2025-07-16T18:11:12.741Z root INFO Initialize the workbench layout: 26.8 ms [Finished 8.576 s after frontend start]
2025-07-16T18:11:12.741Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-07-16T18:11:12.742Z root INFO Replace loading indicator with ready workbench UI (animation): 898.1 ms [Finished 9.505 s after frontend start]
2025-07-16T18:11:12.742Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-07-16T18:11:12.742Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-07-16T18:11:12.742Z root INFO Executing startup tasks:
2025-07-16T18:11:12.742Z root INFO  - 'arduino-use-inherited-boards-config' , args: [{},{}]
2025-07-16T18:11:12.744Z root INFO Frontend application start: 6781.2 ms [Finished 67.222 s after backend start]
2025-07-16T18:11:12.758Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324) starting instance
2025-07-16T18:11:12.778Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Waiting for backend deployment: 9344.8 ms [Finished 17.842 s after frontend start]
2025-07-16T18:11:14.191Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Sync of 23 plugins: 1387.4 ms [Finished 19.229 s after frontend start]
2025-07-16T18:11:14.194Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Loading plugin contributions
2025-07-16T18:11:14.194Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Load contributions of 23 plugins: 30.0 ms [Finished 19.259 s after frontend start]
2025-07-16T18:11:14.274Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-07-16T18:11:14.274Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2025-07-16T18:11:14.966Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-07-16T18:11:14.967Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-07-16T18:11:14.967Z root ERROR [hosted-plugin: 26324] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
2025-07-16T18:11:14.983Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): PluginManagerExtImpl/init()
2025-07-16T18:11:14.985Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-arduino-api@0.1.2 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.056Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(cortex-debug@1.5.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.056Z root INFO [hosted-plugin: 26324] Debugger contribution has been registered: cortex-debug
2025-07-16T18:11:15.060Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-arduino-tools@0.1.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.062Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(cpp@1.52.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.064Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(json@1.46.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.066Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(json-language-features@1.46.1 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.068Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.069Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.070Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-de@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.072Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-es@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.073Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.076Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.078Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-it@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.079Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.079Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.080Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.081Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.082Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.083Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.083Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.084Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.085Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.086Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\plugin-vscode-init)
2025-07-16T18:11:15.094Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-07-16T18:11:15.100Z root INFO [hosted-plugin: 26324] calling activation function on Arduino IDE API for VS Code extensions
2025-07-16T18:11:15.103Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2025-07-16T18:11:15.138Z root INFO [hosted-plugin: 26324] calling activation function on JSON Language Features (built-in)
2025-07-16T18:11:21.497Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-07-16T18:11:21.498Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-07-16T18:11:21.498Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-07-16T18:11:21.499Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-07-16T18:11:21.499Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-07-16T18:11:21.499Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-07-16T18:11:21.499Z daemon INFO time="2025-07-16T11:11:21-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-07-16T18:11:21.501Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
    at Object.callback (C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:82513)
    at Object.onReceiveStatus (C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:946962)
    at Object.onReceiveStatus (C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:942911)
    at Object.onReceiveStatus (C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:942356)
    at C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:1028497
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2025-07-16T18:11:21.501Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2025-07-16T18:11:22.181Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Starting plugins.
2025-07-16T18:11:22.189Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-07-16T18:11:22.256Z root INFO [hosted-plugin: 26324] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-07-16T18:11:22.258Z root INFO [hosted-plugin: 26324] calling activation function on Cortex-Debug
2025-07-16T18:11:22.303Z root INFO [hosted-plugin: 26324] GDB server console created
2025-07-16T18:11:22.316Z root INFO [e8599016-2acf-4a84-a140-161b2dab65f8] Start of 23 plugins: 8105.7 ms [Finished 27.385 s after frontend start]
2025-07-16T18:11:22.385Z root INFO Starting language server: arduino:avr:uno
2025-07-16T18:11:22.396Z root INFO [hosted-plugin: 26324] PLUGIN_HOST(26324): PluginManagerExtImpl/loadPlugin(C:\Users\billh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-07-16T18:11:22.440Z root INFO [hosted-plugin: 26324] calling activation function on VS Code Arduino Tools
2025-07-16T18:11:23.934Z daemon INFO time="2025-07-16T11:11:23-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-07-16T18:11:23.935Z daemon INFO time="2025-07-16T11:11:23-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-07-16T18:11:23.936Z daemon INFO time="2025-07-16T11:11:23-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-07-16T18:11:28.826Z daemon INFO time="2025-07-16T11:11:28-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-07-16T18:11:28.827Z daemon INFO time="2025-07-16T11:11:28-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-07-16T18:11:28.829Z daemon INFO time="2025-07-16T11:11:28-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-07-16T18:11:35.781Z daemon INFO time="2025-07-16T11:11:35-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-07-16T18:11:35.783Z daemon INFO time="2025-07-16T11:11:35-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-07-16T18:11:35.786Z daemon INFO time="2025-07-16T11:11:35-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-07-16T18:11:53.813Z root INFO Executing 'arduino.languageserver.notifyBuildDidComplete' with "file:///c%3A/Users/billh/AppData/Local/arduino/sketches/93727EB331FF321CA0B0718797B8C3A4"
2025-07-16T18:11:53.893Z daemon INFO time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-07-16T18:11:53.893Z daemon INFO time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-07-16T18:11:53.893Z daemon INFO time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-07-16T18:11:53.894Z daemon INFO time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-07-16T18:11:53.894Z daemon INFO time="2025-07-16T11:11:53-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-07-16T18:11:53.895Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
2025-07-16T18:11:53.895Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2025-07-16T18:11:54.859Z daemon INFO time="2025-07-16T11:11:54-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-07-16T18:11:54.860Z daemon INFO time="2025-07-16T11:11:54-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-07-16T18:11:54.862Z daemon INFO time="2025-07-16T11:11:54-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\billh\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-07-16T18:11:57.886Z root INFO Received port after upload [arduino+serial://COM4, arduino:avr:uno, ASCIITable]. Before port: {"protocol":"serial","address":"COM4"}, after port: {"address":"COM4","addressLabel":"COM4","protocol":"serial","protocolLabel":"Serial Port (USB)","properties":{"pid":"0x7523","serialNumber":"","vid":"0x1A86"}}
2025-07-16T18:12:01.722Z root ERROR Could not parse the pluggable monitor settings file. Using empty file.
2025-07-16T18:12:01.745Z daemon INFO time="2025-07-16T11:12:01-07:00" level=info msg="Starting monitor process" monitor=serial-monitor
2025-07-16T18:12:02.804Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2025-07-16T11:12:02-07:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 1.1.1\"" monitor=serial-monitor
2025-07-16T18:12:02.835Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2025-07-16T18:12:02.835Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2025-07-16T18:12:02.838Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
2025-07-16T18:12:02.839Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
2025-07-16T18:12:02.839Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2025-07-16T18:12:02.839Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="Killing monitor process" monitor=serial-monitor
2025-07-16T18:12:02.845Z daemon INFO time="2025-07-16T11:12:02-07:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2025-07-16T18:12:02.846Z daemon INFO time="2025-07-16T11:12:02-07:00" level=error msg="Waiting for process end" error="exit status 1" monitor=serial-monitor
2025-07-16T18:12:02.846Z daemon INFO time="2025-07-16T11:12:02-07:00" level=info msg="Monitor process killed" monitor=serial-monitor
