Serial output from any pin?
I need to output serial packets from a standard I/O pin without remapping a SERCOM port to it as i only need output (TX) not input (RX) and SERCOM requires a valid pin for each, more specifically a valid pair. i know this is possible as it can be done with bit-banging the data but that seems like an extremely crude solution, despite my googling i have been unable to find any libraries for- or discussions about- this topic.
the arduino is a ZERO so 48mhz clock and can directly handle 32bit operations. does anyone know of a library for this purpose or a "standard" / "propper" way of doing this?.
it shouldn't be relevant but the application is SBUS output which is a 100000 baud 8E2 inverted serial signal, the inversion is done with external hardware. the SBUS packet is stored as an array of bit-shifted 8-bit bytes.
I'm not familiar with the processor on your board and I don't have the board.
Maybe below from the M0 datasheet might point you in the right direction:
Well, there is Duino-hacks/DumbTXSWS/src/DumbTXSWS.cpp at master · WestfW/Duino-hacks · GitHub (bit-banging), but it depends on delayMicroseconds() and digitalWrite() being "fast" compared to the bit time, and I suspect that it won't do very well on a 48MHz SAMD at 100kbps.
Can you pick a pin that is tied to TxD for one of the other Sercom peripherals? A custom SerCom driver could avoid configuring the receive pin...
Are you that short of pins? Just because you define and enable an RX pin, doesn't mean you have to actually connect anything to it (although a pullup is a good idea!)
