A few weeks ago I started to use my wemos d1 mini and wemos d1 mini pros for the first time in a while.
I had since upgraded to the new version of MacOS and my d1 mini wouldn't show up anymore. I found help online that said to remove the kext drivers as MacOS now comes with them.
I did that and it worked.
This then meant that my d1 mini pro stopped working.
I re-downloaded the c210x drivers from silicon labs and then I got both working again.
So tonight I was messing around with my d1 mini with no issues at all.
I then tried to use my d1 mini pro and I keep getting an error when trying to upload code to it, it says the port is busy.
The port does show up in arduino and in the terminal as - /dev/tty.usbserial-017AC3B9
I tried doing lsof and it doesn't show up in the output.
I tried removing the drivers again, doesn't work.
I tried reinstalling the drivers again doesn't work.
I tried "screen /dev/tty.usbserial-017AC3B9 9600", it also says it is busy.
I am using the same cable that works with the d1 mini.
I have tried 2 d1 mini pros and both don't work.
I have been banging my head against the wall for hours and nothing is working, anyone any ideas?
My working d1 mini shows up as - /dev/tty.usbserial-1410 if that helps for any reason
Arduino error:
Executable segment sizes:
IROM : 227372 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26360 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24848 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 255656 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26772 bytes (32%) of dynamic memory, leaving 55148 bytes for local variables. Maximum is 81920 bytes.
An error occurred while uploading the sketch
Traceback (most recent call last):
esptool.py v2.8
Serial port /dev/cu.usbserial-017AC3B9
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 16] Resource busy: '/dev/cu.usbserial-017AC3B9'
During handling of the above exception, another exception occurred:
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/Users/avance/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 16] could not open port /dev/cu.usbserial-017AC3B9: [Errno 16] Resource busy: '/dev/cu.usbserial-017AC3B9'
