I installed Arduino on Fedora 21 with 'yum instll arduino'
When I run it the 'Tools -> Serial Port' menu option is grayed-out and can not be set.
And when I try to open the serial monitor window I get this messages on the terminal:
Jar version = RXTX-2.2
native lib Version = RXTX-2.2pre2
processing.app.SerialNotFoundException: Serial port '/dev/ttyS1' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.(Serial.java:192)
at processing.app.Serial.(Serial.java:92)
at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:207)
at processing.app.Editor.handleSerial(Editor.java:2508)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:353)
at java.awt.Component.processMouseEvent(Component.java:6522)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6290)
at java.awt.Container.processEvent(Container.java:2234)
at java.awt.Component.dispatchEventImpl(Component.java:4881)
at java.awt.Container.dispatchEventImpl(Container.java:2292)
at java.awt.Component.dispatchEvent(Component.java:4703)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4898)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4530)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4462)
at java.awt.Container.dispatchEventImpl(Container.java:2278)
at java.awt.Window.dispatchEventImpl(Window.java:2739)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:746)
at java.awt.EventQueue.access$400(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:697)
at java.awt.EventQueue$3.run(EventQueue.java:691)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:719)
at java.awt.EventQueue$4.run(EventQueue.java:717)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:716)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
I added the user to the dialout group, and I changed COM1 to ttyS0 in .arduino/preferences.txt
And this happens even when I run it as a root.
I wonder if anyone could suggest a solution?
Andrei
