Serial port stops receiving data after random amount of time
EDIT: I'm currently using an Arduino Nano 33 IoT
Hi, I'm currently working on a project where I need to measure distances at two different points using distance sensors (I'm currently using VL53L4CD laser distance sensors). However, this project requires a high sampling rate of 100Hz. To achieve this, I have 4 distance sensors arranged into 2 sensor sets. Each sensor set consists of 2 distance sensors (So for example, sensor set 1 consists of distance sensor 2&3 and sensor set 2 consists of distance sensor 1&4) and I would alternate between reading each sensor set.
This seemed to work at first, I did get a new distance reading every 8ms. However, the serial port stops receiving the distance readings after a very random amount of time. Sometimes the serial port stops receiving new data after 5 seconds, sometimes 30s, sometimes 60 and even 180s.
I'm not sure what's causing this issue what I can do to fix it. Any help is appreciated.
Thanks!
Here is my code below:
// Included libraries
#include <Arduino.h>
#include <Wire.h>
// Libraries required for VL53L4CD sensors
#include <vl53l4cd_class.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include <assert.h>
#include <stdlib.h>
// Definitions
#define DEV_I2C Wire
#define SerialPort Serial
// variables
int alternate = 0; // Variable used to alternate between sensor sets
// Components.
VL53L4CD sensor_vl53l4cd_1(&DEV_I2C, 2); // xshut pin of distance sensor 1 connected to pin 2
VL53L4CD sensor_vl53l4cd_2(&DEV_I2C, 3); // xshut pin of distance sensor 2 connected to pin 3
VL53L4CD sensor_vl53l4cd_3(&DEV_I2C, 5); // xshut pin of distance sensor 3 connected to pin 5
VL53L4CD sensor_vl53l4cd_4(&DEV_I2C, 6); // xshut pin of distance sensor 4 connected to pin 6
/* Setup ---------------------------------------------------------------------*/
  // DISTANCE SENSOR SETUP
  // Initialize serial for output.
  SerialPort.begin(9600);
  SerialPort.println("Starting...");
  // Initialize I2C bus.
  DEV_I2C.begin();
  // Configure VL53L4CD number 1
  Serial.println("Configuring distance sensor 1");
  sensor_vl53l4cd_1.begin();
  sensor_vl53l4cd_1.VL53L4CD_Off();
  sensor_vl53l4cd_1.InitSensor();
  sensor_vl53l4cd_1.VL53L4CD_SetI2CAddress(0x40);
  sensor_vl53l4cd_1.VL53L4CD_SetRangeTiming(10, 0);
  // Configure VL53L4CD number 2
  Serial.println("Configuring distance sensor 2");
  sensor_vl53l4cd_2.begin();
  sensor_vl53l4cd_2.VL53L4CD_Off();
  sensor_vl53l4cd_2.InitSensor();
  sensor_vl53l4cd_2.VL53L4CD_SetI2CAddress(0x42);
  sensor_vl53l4cd_2.VL53L4CD_SetRangeTiming(10, 0);
  // Configure VL53L4CD number 3
  Serial.println("Configuring distance sensor 3");
  sensor_vl53l4cd_3.begin();
  sensor_vl53l4cd_3.VL53L4CD_Off();
  sensor_vl53l4cd_3.InitSensor();
  sensor_vl53l4cd_3.VL53L4CD_SetI2CAddress(0x44);
  sensor_vl53l4cd_3.VL53L4CD_SetRangeTiming(10, 0);
  // Configure VL53L4CD number 4
  Serial.println("Configuring distance sensor 4");
  sensor_vl53l4cd_4.begin();
  sensor_vl53l4cd_4.VL53L4CD_Off();
  sensor_vl53l4cd_4.InitSensor();
  sensor_vl53l4cd_4.VL53L4CD_SetI2CAddress(0x46);
  sensor_vl53l4cd_4.VL53L4CD_SetRangeTiming(10, 0);
  // Start Measurements
  sensor_vl53l4cd_1.VL53L4CD_StartRanging();
  sensor_vl53l4cd_2.VL53L4CD_StartRanging();
  sensor_vl53l4cd_3.VL53L4CD_StartRanging();
  sensor_vl53l4cd_4.VL53L4CD_StartRanging();
  // Read results from sensor set 1
  if (alternate == 0){
    VL53L4CD_Result_t results2;
    VL53L4CD_Result_t results3;
    // Read results from sensor set 1 (Sensors 2 and 3)
    sensor_vl53l4cd_2.VL53L4CD_ClearInterrupt();
    sensor_vl53l4cd_2.VL53L4CD_GetResult(&results2);
    sensor_vl53l4cd_3.VL53L4CD_ClearInterrupt();
    sensor_vl53l4cd_3.VL53L4CD_GetResult(&results3);
    Serial.print("Distance 1-1 = ");
    Serial.print(results2.distance_mm);
    Serial.println(" ");
    Serial.print("Distance 1-2 = ");
    Serial.print(results3.distance_mm);
    alternate = 1; // Change value so sensor set 2 is read in the following loop
  // Read results from sensor set 2
  else if (alternate == 1){
    VL53L4CD_Result_t results1;
    VL53L4CD_Result_t results4;
    // Read results from sensor set 1 (Sensors 1 and 4)
    sensor_vl53l4cd_1.VL53L4CD_ClearInterrupt();
    sensor_vl53l4cd_1.VL53L4CD_GetResult(&results1);
    sensor_vl53l4cd_4.VL53L4CD_ClearInterrupt();
    sensor_vl53l4cd_4.VL53L4CD_GetResult(&results4);
    Serial.print("Distance 2-1 = ");
    Serial.print(results1.distance_mm);
    Serial.print("Distance 2-2 = ");
    Serial.print(results4.distance_mm);
    alternate = 0; // Change value so sensor set 2 is read in the following loop
   Serial.println(millis());
Which MCU is being used?
How are the sensors using more than 2 I2C address? Some I2C devices allow for an alternate I2C so that 2 same type devices can be used. I2C devices having 3 or 4 I2C address is not common.
From looking at some deets
I do not see a pin to set an alternate I2C address for the module, you?
The schematic does not show a way to set an alternate address.
An experiment, you could cut the traces to the AVSSVCSEL lines and pull and individual pin high, run the I2C scanner to see if the address has changed. That's at your own risk.
Hi, thanks for the reply.
I'm using an Arduino Nano 33 IoT. Each of the 4 sensors has its own unique I2C address. They do not have more than one I2C address assigned to each of them.
The VL53L4CD sensor does allow the I2C address to be changed using Adafruit's library for the VL53L4CD sensor. I have verified that the address does change using an I2C scanner.
The library can be found here: VL53L4CD/vl53l4cd_class.h at main · stm32duino/VL53L4CD · GitHub
