Serial print or read problem
Why does 491310 show this in response to the number 1?
serial
491310 is ASCII 49 (ie 1) ASCII 13 (ie Carriage Return) and ASCII 10 (ie Linefeed)
If you enter 2 then you will get 501310 and so on. The CR and LF are being added by the Serial monitor Line ending setting
What happens if you use Serial.write() ?
No Clue. Please read the forum guidelines and post appropriately using code tags.
uyarı yazacağın yardım etsene amk evladı
i need use print...
Why did you post that ?
Give me a good reason not to ban you
Start by posting the code in code tags so that it can be easily copied
Did you actually try using Serial.write() ?
Since my English is bad, I have difficulty finding the relevant topic. Write does not work for me, I need print.
Your English may be bad but I can see no reason why you posted what you did in Turkish
Should I see you posting like that again you will be banned. Consider yourself warned.
In what way does Serial.write() not work for you and why have you not posted your sketch properly in code tags ?
If you insist on using Serial.print() then try this
Serial.print((char)i);
lan amk evladı sen ingilizce yazıyorunda ben neden kendi ana dilimde yazamayayım ? sokarım banına da sanada amk ingiliz yavşağı
@aslan1983 has been banned for abusive language
