Serial.println communication with the HC-05 module
Hi. I want to send the data that I obtain from sensors from the command Serial.println to the phone through the Bluetooth module HC-05, but with the code that I'm using I can only send to the phone the data that I type in the serial monitor of the pc. I would be really grateful if someone could help me with this issue. Here is the code that I'm using: (In this case, I'm testing the module with the detection of a PIR sensor, I want to receive the "Motion detected" or "No motion" in the phone).
int sensorPin= 7;
int val = 0;
#include <SoftwareSerial.h>
SoftwareSerial BSerial(2,3);
  BSerial.begin(9600);
  pinMode(sensorPin, INPUT);
for(int i = 0; i > 30; i++)
delay(50);
if (BSerial.available()) {
    Serial.write(BSerial.read());
  if (Serial.available()) {
    BSerial.write(Serial.read());
  val = digitalRead(sensorPin);
if (val == HIGH)
Serial.println("Motion detected!");
Serial.println("No motion");
What type of sensors are you using ?
Can you read the data from the sensors and print it to the Serial monitor ?
Instead of
have you tried
BSerial.println("Motion detected!");
Oh, perfect, now it works, thank you so much, I'm new to programming.
