Hi everyone,I am wondering if I can use a single HC-05 Module to send sensor data to my smartphone and also using my phone to send commands to the Arduino for controlling something,if you are wondering how i am going to send and receive data on my phone if most traditional Bluetooth apps only support 1 way modes,it's with a self made app that I made on the mit app inventor.I would like to know if it is possible and what kind of serial (or other) commands I would have to include in my code,and if a traditional Rx to tx and tx to Rx wiring would work.
No.
Yes.
Wifi, RF
Thanks for the simple and straightforward reply railroder,do you have any idea of how i can transfer sensor data wirelessly to my phone?
edit:railroader not railroder
what sensors ?
what do you want to do with the data on the phone?
e..g.display it (text, graphs, etc) using an app? existing app or will you implement one?
I have a dht11 temp and humidtiy sensor and I intend to use a temperature probe to measure water temperature as my project has to do with water
I intend to display it as text
And a current sensor and I will be measuring a analog voltage
All of Which I intend to display on my phone as text on my app which as mentioned above I made with the mit app inventor
simple to send text to an Android and display it using Serial Bluetooth Terminal
have a look at arduino-micro-sends-with-hc-06-but-wont-receive using a HC-06 to send text to an Android serial terminal
Thanks,what kind of code do I need on the arduino side though? just serial.print or what would I need
thank you @horace for the anwser
Yes. The best kept secret about Bluetooth is that that is all you need...
In the immortal words of some guru round here: " Serial is serial, and Bluetooth is just serial, but without wires"
Thanks everyone for all the answers I really appreciate your help and thanks for answering my question.
