Greetings and Salutations!
I was trying to find a solution to being able to write text live to a 32x16 DMD. I have managed to create the below code to accomplish this. I have this working to an extent, however I seem to have an issue with loosing Characters from my input.
eg. I Type "This is my example string" into my Serial Monitor.
The output I get to my screen (and whats written to the String) is random and can be something like "This is my exe string" or "This is my examptring".
This must be to do with this section of my code. But I'm lost as to what may be causing it.
inData[index] = inChar; // Store it
index++; // Increment where to write next
while(Serial.available() > 0){
if(index < 254){
inChar = Serial.read(); // Read a character
delay(200);
inData[index] = 0; // Null terminate the string
I'm still learning how to program for Arduino, so I do apologise if it is a bit messy.
I appreciate any help you may be able to provide.
Thank you,
DJD
The Full code for this project is:
Serial Read and Display.
This project is designed to Read inputs from Serial and Display the input on a
Freetronic 32x16 Dot Matrix Display.
To wipe your existing String simply input a Tilda (~) into your Serial Command.
Note, for debugging purposes, Serial.print has been used in both the Stop Display
and Write Display loops. These can be removed.
Includes
#include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h> //
#include <TimerOne.h> //
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
//Fire up the DMD library as dmd
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
char inData[255]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
void ScanDMD(){
dmd.scanDisplayBySPI();
void setup(void){
Serial.begin(57600);
Serial.write("Power On");
//initialize TimerOne's interrupt/CPU usage used to scan and refresh the display
Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
//clear/init the DMD pixels held in RAM
dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
dmd.selectFont(Arial_Black_16);
void loop(void){
while(Serial.available() == 0){ //check to see if data on Serial
if (index > 0){ // if index is greater than 0, data must exist in inData, so display text. Otherwise do nothing.
display_text();
}else{
if (inChar == '~') { // ~ is the command to stop display of any text and to wipe the inData String.
cancel_text();
}else{
write_text(); // This will write your Serial text to a String. Note if you do not ~ before typing a new string, this will append your new string to the previous one.
// Command to Stop Display and wipe InData String/Reset index.
void cancel_text(){
index = 0;
*inData = 0;
Serial.println("Cancel");
// Read Serial and Write to String to be Displayed.
void write_text(){
if(index < 254){
delay(200);
// Scrolling Text the inData string on a 32x16 DMD
void display_text(){
Serial.println(inData);
dmd.drawMarquee(inData,index,(32*1)-1,0); // This uses the Freeduino 32x16 DMD
long start=millis();
long timer=start;
boolean ret=false;
while(!ret){
if ((timer+30) < millis()) { //Speed of Marquee Text
ret=dmd.stepMarquee(-1,0);
timer=millis();
