Serial.read Data to An Array
Hello,
How do I read received serial data and arrange it into an array?
Let just say the Arduino receives these values...
11,22,33,44,55,66
From the array that would be created. I could then grab certain values from it.
myArray[1] would equal "22"
Does it make sense to make the data into a string then make the string into an array? If so how would you do that?
Thank you
Read this: https://www.baldengineer.com/arduino-multi-digit-integers.html
AFTER You get a number, you can assign it to an array element then increase the index by 1 and get the next numeric input.
There are lots of ways to do this, expect lots of different answers.
One can store the characters and convert to numeric after the inputs:
https://forum.arduino.cc/t/how-to-store-values-in-a-list-or-array/606820
The serial input basics tutorial shows how to receive serial data into a null terminated character array (string) and parse the data.
A demo code using the serial input basics receive with end marker and the strtok() function parse the string array to integers. Enter up to six integer numbers separated by commas, like 11,22,33,44,55,66.
Make sure newline is enabled in serial monitor line endings.
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
int number_1;
int number_2;
int number_3;
int number_4;
int number_5;
int number_6;
   Serial.println("<Arduino is ready>  Enter up to six integer numbers separated by commas");
   Serial.println("Like 11,22,33,44,55,66");
   Serial.println("make sure newline is enabled in serial monitor line endings");
   recvWithEndMarker();
   showNewData();
   if (newData)
      parseData();
void recvWithEndMarker()
   static byte ndx = 0;
   char endMarker = '\n';
   char rc;
   while (Serial.available() > 0 && newData == false)
      rc = Serial.read();
      if (rc != endMarker)
         receivedChars[ndx] = rc;
         ndx++;
         if (ndx >= numChars)
            ndx = numChars - 1;
         receivedChars[ndx] = '\0'; // terminate the string
         ndx = 0;
         newData = true;
void showNewData()
   if (newData == true)
      Serial.print("This just in ... ");
      Serial.println(receivedChars);
      //newData = false;
void parseData()
   char *strings[8]; // an array of pointers to the pieces of the above array after strtok()
   char *ptr = NULL; byte index = 0;
   ptr = strtok(receivedChars, ",");  // delimiters, semicolon
   while (ptr != NULL)
      strings[index] = ptr;
      index++;
      ptr = strtok(NULL, ",");
   //Serial.println(index);
   // print all the parts
   Serial.println("The Pieces separated by strtok()");
   for (int n = 0; n < index; n++)
      Serial.print("piece ");
      Serial.print(n);
      Serial.print(" = ");
      Serial.println(strings[n]);
   // convert string data to numbers
   number_1 = atoi(strings[0]);
   number_2 = atoi(strings[1]);
   number_3 = atoi(strings[2]);
   number_4 = atoi(strings[3]);
   number_5 = atoi(strings[4]);
   number_6 = atoi(strings[5]);
   Serial.print("number 1 = ");
   Serial.print(number_1);
   Serial.print("   number 2 = ");
   Serial.print(number_2);
   Serial.print("   number 3 = ");
   Serial.print(number_3);
   Serial.print("   number 4 = ");
   Serial.print(number_4);
   Serial.print("   number 5 = ");
   Serial.print(number_5);
   Serial.print("   number 6 = ");
   Serial.print(number_6);
   Serial.println(); // blank line
   newData = false;
consider
output
     11  11
     22  22
     33  33
     44  44
     55  55
     66  66
char s [80];
#define MaxTok  10
char *toks [MaxTok];
int   vals [MaxTok];
int
tokenize (
    char       *s,
    const char *sep )
    unsigned n = 0;
    toks [n] = strtok (s, sep);
    vals [n] = atoi (toks [n]);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void dispToks (
    char * toks [])
    char s [40];
    for (unsigned n = 0; toks [n]; n++)  {
        sprintf (s, " %6d  %s", vals [n], toks [n]);
        Serial.println (s);
void loop ()
    if (Serial.available ())  {
        int n = Serial. readBytesUntil ('\n', s, sizeof(s));
        s [n] = 0;      // terminate string
        tokenize (s, ",");
        dispToks (toks);
void setup ()
    Serial.begin (9600);
