#include <Wire.h>
#include <ivafruit_ADS1015.h>
#include <Adafruit_ADS1015.h>
#include <SoftwareSerial.h>
#include<string.h>
#include<stdio.h>
Adafruit_ADS1115 ads1115 (0x49);
ivafruit_ADS2224 ads2224 (0x48);
String inputString = "";
String newstring="";
#define disk1 0X10//Address of dac chip
#define relayadd 0X41 //Address of dac chip
int integerValue=0;
unsigned int outValue=0xff; //intial off state for relay
const int buttonPin0 =A0;
const int buttonPin1 =A1; // the number of the pushbutton pin
int buttonState0, buttonState1 =HIGH;
const int EN =9;
const int a0 =10;
const int a1 =11;
void dac(int deviceaddress, unsigned int eeaddress,int data )
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress));
Wire.write((int)(data >> 4));
Wire.write((int)(data << 4));
Wire.endTransmission();
void relay(int address, unsigned int count,int out )
Wire.beginTransmission(address);
Wire.write((int)(count));
Wire.write((int)( out ));
void setup(void)
pinMode(buttonPin0, INPUT);
pinMode(buttonPin1, INPUT);
pinMode(EN, OUTPUT);
pinMode(a0, OUTPUT);
pinMode(a1, OUTPUT);
Wire.begin();
ads1115.begin();
ads2224.begin();
Serial.println("WELCOME");
//ads1115.setGain(GAIN_SIXTEEN);
void loop(){
unsigned int address = 0X30; // this for relay address
int16_t adc0;
int16_t outputValue;
int16_t iadc0, iadc1;
float ivolt0, ivolt1,volt0;
long int volt1;
unsigned int cont = 0X03;// this relay control select bit
buttonState0 = digitalRead(buttonPin0);
buttonState1 = digitalRead(buttonPin1);
if (buttonState0 == LOW) {
//DO SOME
if (buttonState1 ==LOW) {
//DO SOME
if(Serial.available()>0) {
char inChar = Serial.read(); // char
inputString += inChar;
if (inChar == '*') {
if(inputString[0]=='Y')
outValue=0xf0;
if(inputString[0]=='N')
outValue=0xff;
//Serial.println( inputString);
if(inputString[0]=='I')
int i;
int len=inputString.length();
for(i=0;i<len;i++)
if (isDigit(inputString*))*
_ char m=inputString*;_
_ newstring += m;_
_ }_
_ }_
_ integerValue= newstring.toInt();*_
_ integerValue= (integerValue)*40; //to convert the user value into arround 4000 range_
* if(inputString[0]=='L')*
* int k=26;*
* Serial.println('k');*
* if(inputString=="S1")*
* digitalWrite(EN,HIGH);*
* digitalWrite(a0,LOW);*
* digitalWrite(a1,LOW);*
* else if(inputString=="S2")*
* digitalWrite(a0,HIGH);*
* else if(inputString=="S3")*
* digitalWrite(a1,HIGH);*
* else if(inputString=="S4")*
* else*
* digitalWrite(EN,LOW);*
* } inputString = "";*
* newstring=" " ;*
* Serial.println(integerValue);*
* dac(disk1, address, integerValue);*
* relay(relayadd, cont, outValue);*
* adc0 = ads1115.readADC_SingleEnded(0);
iadc0 = ads2224.readADC_SingleEnded1(0);
_ volt0 = adc00.000188;
* volt0 = adc0/4926.470588;*
* ivolt0 = iadc0/4926.470588;*
//volt1=volt0*100;_
* //Serial.print(adc0);*
* //Serial.print(",");*
* //Serial.print("RCV");*
* //Serial.println(volt0,3);*
* //Serial.println(ivolt0,3);*
* //delay(1000);*
THIS IS MY TOTAL CODE.
the output is given heare
the intialy print 0 continuesly.
if i give I10*(enter the send tab) that time print 400 is work prefect
after i give any value not change it that means continusley print same 400. when i again dump the code it print intial value 0 and i entered some value in send tab that vale printed.but i give second time the value do not printed this is my problem can u help me
