Clear the string
Hello guys !
I need to clear my string I tried putting serial.read() on several locations or '""' (putting it blank ). But the first character I sent my program remembers , it never changes when I sent other characters
For Example : I sent V,123 and then A,123 It will always return me the first character I got wich in this example is "V". For the axis this is no problem there it does overwrite the old axis value.
So it must be a clear buffer problem ... How do I solve this ?
Using :
Arduino uno
#define E1 10  // Enable Pin for motor 1
#define E2 11  // Enable Pin for motor 2
#define I1 8  // Control pin 1 for motor 1 for L293D it changes the direction of the motor
#define I2 9  // Control pin 2 for motor 1 for L293D it changes the direction of the motor
#define I3 12  // Control pin 1 for motor 2 for L293D it changes the direction of the motor
#define I4 13  // Control pin 2 for motor 2 for L293D it changes the direction of the motor
String Richting;  // Direction
int Axis;                 // Numbers (the speed I want to set on the motors)
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
  Serial.begin(2400);
  pinMode(13, OUTPUT);
  pinMode(E1, OUTPUT);
  pinMode(E2, OUTPUT);
  pinMode(I1, OUTPUT);
  pinMode(I2, OUTPUT);
  pinMode(I3, OUTPUT);
  pinMode(I4, OUTPUT);
  Serial.println("<Arduino is ready>");
  if (recievedMessage())
    parseMessage();
    Calculation();
    showNewMessage();
bool recievedMessage() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (rc != endMarker) {
      receivedChars[ndx] = rc;
      ndx++;
      Richting = receivedChars[1];
      if (ndx >= numChars) {
        ndx = numChars - 1;
    else {
      receivedChars[ndx] = '\0'; // terminate the string
      ndx = 0;
      newData = true;
      return true;
  return false;
void showNewMessage() {
  if (newData == true) {
    Serial.println(Richting);
    newData = false;
void parseMessage()
  strtok(receivedChars, ",");
  Axis = atoi(strtok(NULL, ","));
void Calculation()
  if (Richting = "A") {
    analogWrite(E1, Axis * 2);
    analogWrite(E2, Axis * 2);
    digitalWrite(I1, HIGH);
    digitalWrite(I2, LOW);
    digitalWrite(I3, HIGH);
    digitalWrite(I4, LOW);
hello @MrKrabs ;D
you moved the assignment of the direction (Richting) into the recievedMessage() function... why?
you seem to have refactored your code beyond that as well....
      ndx++;
        ndx = numChars - 1;  // ????????????
EDIT: @Robin2... he's using your global examples....
MrKrabs:
Hello guys !
This will zero-out/clear the whole array to zero-bytes:
memset(receivedChars,0,sizeof(receivedChars));
After doing so, then length of the string is 0 with a finalizing '\0' character (nullterminated string with zero length).In fact, ALL positions of the array will contain zero-bytes.
Hello BulldogLowell !
No I didn't change that part of the code this is actually raw copy and pasted from Robin go check it out it's true ;).
Are you sugesting I shouldn't use global variables ??
I never mind I see what you mean , you are talking about richting my bad ... Yes Because before every full string I sent char 22 wich is a sync if you look in the ascii-table. So a full string would be char 22 + direction + ","+axis+char 13 +char 10 that's why.
Weren't you already warned about this in a previous thread?
arduarn:
LOL, and these:
line 10:   String Richting;  // Direction
line 19:   pinMode(13, OUTPUT);
line 51:   Richting = receivedChars[1];
line 70:   Serial.println(Richting);
line 84:   if (Richting="V"){
I even provided the complete sketch:
const byte numChars = 75;
  Serial.begin(2400);
  // pinMode(13, OUTPUT); <-- This is the same as I4!
    parseMessage();
    Calculation();
    showNewMessage();
  while (Serial.available()) {
    char rc = Serial.read();
    if (rc >= ' ') { // Not a CR orLF
      if (ndx < numChars) {  // if there's room...
        receivedChars[ndx] = rc;  //  ... save another char
        ndx++;
    } else if (ndx > 0) { // not an empty string
      ndx     = 0;
      newData = true;
      return true;
  return false;
  if (newData) {
    Serial.print("De richting=");
    Serial.println(receivedChars);
    Serial.print("De snelheid=");
    Serial.println(Axis);
    newData = false;
void parseMessage()
void Calculation()
  if ( strcmp( receivedChars, "V" ) == 0 ){
    digitalWrite(I4,HIGH); // <-- use I4, not 13
    analogWrite(E1,255);
But he said he didn't need it because "it just worked suddenly."
Oh, well.
