Serial Terminal Interface
Greetings,
I am attempting to communicate with my Arduino Mega using a standard "telnet" terminal through my computer's serial port.
It is working, when I send a character it shows up in the monitor, but it is gibberish even though I have the baud settings the same on both my terminal and the Arduino ports (9600).
Here is the full sketch:
  // initialize both serial ports:
  Serial3.begin(9600);
  // read from port 3, send to port 0:
  if (Serial3.available()) {
    int inByte = Serial3.read();
    Serial.print(inByte, BYTE);
In my terminal I have it set to 9600,8,N,1, and when I sent "test" I get this in the monitor:
QSt
Any hints/ideas/links/etc. would be greatly appreciated!
Thank you.
Try: if (Serial.available() > 0) {
from example at: Serial.available() - Arduino Reference
Lefty
Thanks for that, now when I send "test" I get:
I received: 81
I received: 83
I received: 116
I received: 4
Instead of: int inByte = Serial3.read();
Try: char inByte = Serial3.read();
Hmmm, same thing, and when I print BYTES instead, I get the same as my first results:
I received: Q
I received: S
I received: t
I received:
Hum, well I'm a hardware guy at heart, I'll let the software gurus around here take up your cause. :wink:
You might try running the telnet and software serial at 2400 bps to see if there is a difference. I would think software serial would be somewhat timing critical when receiving data.
There's some general stuff about Arduinos and serial comms at...
@zoomkat: I have tried at every standard baud, and get varying results with different baud rates - but nothing that works (similar results as my first post). Also, I am using hardware serial ports, not software.
@tkbyd: Thanks for the link, I went over everything there, and I don't see any explanation or reason for the results that I am seeing. The bytes he sends is simply the bytes he receives here:
I am even more stumped now!
How do you connect your Arduino to your PC's Telnet port? Are you aware of the difference between TTL and RS-232?
@BenF: The rx and tx is hooked up straight from the serial port of the PC to the arduino.
The guide link posted by tkbyd states that the voltage is not the same and a PC serial port can fry an arduino, but I already had it hooked before I read that, and sense it didn't fry it I assumed it must be OK.
Might you please explain the difference or provide a link that does?
How can it even works?
A 0 in rs-232 is a 12v signal and a 1 is a -12v signal, how can your arduino can even still work after getting -12v in one pin?
To connect an rs-232 device as your pc, you need a transceiver, that is basically a signal(voltage) shifter, such as max232
Holy smokes! I did not know that - I always thought rs-232 was 5v, like the parallel port!
I have no idea why it was somewhat working at all. So I have to convert the signal it to 5v/-5v and it should work?
A more practical solution is to build a rs-232 to ttl voltage converter, most utilize a max232 chip or equivalent. Another method is to purchase a converter:
The TTL voltage levels are +5volt equals a one or a mark (from the
-12v rs-232 state and ground equals zero or a space (from the +12v rs-232 state).
A more fundamental questions is why are you not using the USB serial interface built into your mega? Your board has a FTDI USB serial converter chip that can handle both uploading new sketches to your board as well as to communicate to any PC program that can work with a comm port.
@retrolefty: thanks for the link! The sparkfun solution looks less expensive than the Max232 chip. Here is my parts list to build one:
1 @ $5.09: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=MAX3323EEPE%2B-ND
4 @ $0.11: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P13460-ND
1 @ $1.99: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A31484-ND
1 @ $9.12: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=923273-ND
Thats really good to know about the USB port too. Eventually though, I will need to simulate (using a PC instead of instruments) for four simultaneous RS-232 devices (one for each serial port on the Mega).
So I just got a RS-232 converter to TTL and it is still doing the same exact thing.
This is starting to drive me crazy, it seems like a quite fundamental goal.
Can anyone suggest how to set up the serial connection? What settings to use for the serial program?
It seems it must be some weird text encoding or setting.
Thanks!
Exactly the same thing as before you put the TTL / RS232 converter in line.
I don't think so.
If it truly is doing the same thing then you have not connected it up correctly.
