'Serial2' was not declared in this scope
Bonjour à tous !
Depuis quelques temps j'ai cette erreur sur mon code :
Je ne comprends pas pourquoi, avant cela fonctionnait bien :frowning: Que faire ?
Mercii
Mon code :
//https://github.com/JosefKrieglstein/AxpertControl/blob/master/axpert.py
String QPIGS = "\x51\x50\x49\x47\x53\xB7\xA9\x0D"; //Lecture live data
String QPIWS = "\x51\x50\x49\x57\x53\xB4\xDA\x0D";
String QDI = "\x51\x44\x49\x71\x1B\x0D";
String QMOD = "\x51\x4D\x4F\x44\x49\xC1\x0D";
String QVFW =  "\x51\x56\x46\x57\x62\x99\x0D";
String QVFW2 = "\x51\x56\x46\x57\x32\xC3\xF5\x0D";
String POP02 = "\x50\x4F\x50\x30\x32\xE2\x0B\x0D";  //SBU priority
String POP01 = "\x50\x4F\x50\x30\x32\xE2\xD2\x69";  //solar first
String POP00 = "\x50\x4F\x50\x30\x30\xC2\x48\x0D";  //utility first
//QPIGS  Lecture live data
float PIP_Grid_Voltage=0;
float PIP_Grid_frequence=0;
float PIP_output_Voltage=0;
float PIP_output_frequence=0;
int PIP_output_apparent_power=0;
int PIP_output_active_power=0;
int PIP_output_load_percent=0;
int PIP_BUS_voltage=0;
float PIP_Battery_voltage=0;
float PIP_battery_charge_current=0;
float PIP_battery_capacity=0;
float PIP_Inverter_heat_sink_temperature =0;
float PIP_PV_current=0;
float PIP_PV_voltage=0;
float PIP_Battery_voltage_from_SCC =0;
float PIP_battery_discharge_current=0;
int PIP_status;
unsigned long lastMillis=0;
long previousMillis = 0;
long interval = 5000;
  Serial2.begin(2400);
  if (currentMillis - previousMillis > interval) {
    Serial2.print(QPIGS);
    if (Serial2.find("(")) {
        Serial.println("DATA-----------------------------------------");
        PIP_Grid_Voltage=Serial2.parseFloat();
        PIP_Grid_frequence=Serial2.parseFloat();
        PIP_output_Voltage=Serial2.parseFloat();
        PIP_output_frequence=Serial2.parseFloat();
        PIP_output_apparent_power=Serial2.parseInt();
        PIP_output_active_power=Serial2.parseInt();
        PIP_output_load_percent=Serial2.parseInt();
        PIP_BUS_voltage=Serial2.parseFloat();
        PIP_Battery_voltage=Serial2.parseFloat();
        PIP_battery_charge_current=Serial2.parseFloat();
        PIP_battery_capacity=Serial2.parseInt();
        PIP_Inverter_heat_sink_temperature =Serial2.parseInt();
        PIP_PV_current=Serial2.parseFloat();
        PIP_PV_voltage=Serial2.parseFloat();
        PIP_Battery_voltage_from_SCC =Serial2.parseFloat();
        PIP_battery_discharge_current=Serial2.parseFloat();
        PIP_status=Serial2.parseInt();
        Serial.println("Grid voltage: " + String(PIP_Grid_Voltage));        //QPIGS.1 Grid voltage
        Serial.println("Grid frequency: " + String(PIP_Grid_frequence));        //QPIGS.2 Grid frequency
        Serial.println("Out voltage: " + String(PIP_output_Voltage));       //QPIGS.3 Out voltage
        Serial.println("Out frequency: " + String(PIP_output_frequence));       //QPIGS.4 Out frequency
        Serial.println("output apparent power: " + String(PIP_output_apparent_power));     //QPIGS.5 AC output apparent power
        Serial.println("output active power: " + String(PIP_output_active_power));      //QPIGS.6 AC output active power
        Serial.println("Output load percent:  " + String(PIP_output_load_percent));   //QPIGS.7 Output load percent
        Serial.println("PIP_BUS_voltage: " + String(PIP_BUS_voltage));                             //skip
        Serial.println("Battery voltage: " + String(PIP_Battery_voltage));    //QPIGS.9 Battery voltage
        Serial.println("Battery charging current: " + String(PIP_battery_charge_current));     //QPIGS.10 Battery charging current
        Serial.println("Battery capacity: " + String(PIP_battery_capacity)); //QPIGS.11 Battery capacity
        Serial.println("PIP_Inverter_heat_sink_temperature: " + String(PIP_Inverter_heat_sink_temperature));                             //skip
        Serial.println("PIP_PV_current: " + String(PIP_PV_current));                             //skip
        Serial.println("PV Input voltage:  " + String(PIP_PV_voltage));     //QPIGS.14 PV Input voltage
        Serial.println("PIP_Battery_voltage_from_SCC: " + String(PIP_Battery_voltage_from_SCC));                             //skip
        Serial.println("Battery discharge current: " + String(PIP_battery_discharge_current));    //QPIGS.16 Battery discharge current
        Serial.println("PIP_status: " + String(PIP_status));    //QPIGS.17 PIP_status
Tu compiles pour quelle carte?
Pardon, c'est une Wemos D1 uno.
Merci
Bonjour
Sur ce forum le code se met entre balises Code, pas Quote
De mémoire l'Esp8266 qui est présent sur les cartes D1 ne possède pas deux ports série complets.
De toutes façon le premier port est Serial et le second Serial1 !!
C'est dans l'incontournable doc de référence : Reference — ESP8266 Arduino Core 2.7.2-10-g2843a5ac documentation
(Il est étrange que cela ait auparavant fonctionné sur un ESP8266 avec Serial2 et que le compilateur ne donne pas le message d'erreur actuellement constaté)
J'ai corrigé.
Oui, ça fonctionnait sur une arduino mega, mais j'ai le même soucis avec un arduino mega.
C'est un tuto qui fonctionnait pourtant avant : tuto francais arduino onduleur hybride type PIP.doc - Google Drive
la carte Mega dispose bien d'un Serial2 , on n'est pas dans la même configuration
Le message suivant est normal pour un ESP8266 :
