SerialCommand Libary error
Hi
I am using the SerialCommand library in several projects. It would seem after an upgrade there are problems with compiling the library.
this is the error I get:
SerialCommand.cpp: 172:38: error: invalid conversion from 'void (*)()' to 'void (*)(char*)' [-fpermissive]
This is the offending code
CommandList[numCommand].function = function;
The definition in the header
void addCommand(const char *, void(*)());   // Add commands to processing dictionary
the actual function
// Adds a "command" and a handler function to the list of available commands.
// This is used for matching a found token in the buffer, and gives the pointer
// to the handler function to deal with it.
//void(*function)(char* token);
void SerialCommand::addCommand(const char *command, void (*function)())
	if (numCommand < MAXSERIALCOMMANDS) {
		#ifdef SERIALCOMMANDDEBUG
		Serial.print(numCommand);
		Serial.print("-");
		Serial.print("Adding command for ");
		Serial.println(command);
		#endif
		strncpy(CommandList[numCommand].command,command,SERIALCOMMANDBUFFER);
		numCommand++;
		// In this case, you tried to push more commands into the buffer than it is compiled to hold.
		// Not much we can do since there is no real visible error assertion, we just ignore adding
		// the command
		Serial.println("Too many handlers - recompile changing MAXSERIALCOMMANDS");
		#endif
Any ideas what went wrong here please?
If you want a snippet of an answer, you are on the right track.
If you want ALL of the answer, post ALL of your code, and a link to the non-standard library you are using.
Show the declaration or definition of function. The one on the right-hand side of the offending code.
This is the class definition
class SerialCommand
	public:
		SerialCommand();      // Constructor
		#ifndef SERIALCOMMAND_HARDWAREONLY
		SerialCommand(SoftwareSerial &SoftSer);  // Constructor for using SoftwareSerial objects
		#endif
		void clearBuffer();   // Sets the command buffer to all '\0' (nulls)
		char *next();         // returns pointer to next token found in command buffer (for getting arguments to commands)
		void readSerial();    // Main entry point.
		void addDefaultHandler(void (*function)());    // A handler to call when no valid command received.
	private:
		char inChar;          // A character read from the serial stream
		char buffer[SERIALCOMMANDBUFFER];   // Buffer of stored characters while waiting for terminator character
		int  bufPos;                        // Current position in the buffer
		char delim[MAXDELIMETER];           // null-terminated list of character to be used as delimeters for tokenizing (default " ")
		char term;                          // Character that signals end of command (default '\r')
		char *token;                        // Returned token from the command buffer as returned by strtok_r
		char *last;                         // State variable used by strtok_r during processing
		typedef struct _callback {
			char command[SERIALCOMMANDBUFFER];
			void (*function)(char* token); // added the variable to be passed to the function
		} SerialCommandCallback;            // Data structure to hold Command/Handler function key-value pairs
		int numCommand;
		SerialCommandCallback CommandList[MAXSERIALCOMMANDS];   // Actual definition for command/handler array
		void (*defaultHandler)();           // Pointer to the default handler function
		int usingSoftwareSerial;            // Used as boolean to see if we're using SoftwareSerial object or not
		SoftwareSerial *SoftSerial;         // Pointer to a user-created SoftwareSerial object
		#endif
this is the part that is affected
		int numCommand;
I am compiling for Teensy 3.6. Dont know if that is relevant?
No, your function. Please.
OP - Is there some reason you're unable to supply your complete code and a link to the library in question?
Not at all.
The library is at GitHub - scogswell/ArduinoSerialCommand: An Arduino library to tokenize and parse commands received over a serial port.
My Code
 Created:	09/04/2018
 Author:	Marius D. Liebenberg
 Description: controller to move a target at a given speed past a sensor
 in order to test and validate operation parameters.
 The puck will move from one side to the other at a given speed not
 exceeding 10m/s.
 Two selectable speeds are provided as well as a start button for left and right.
 The system will home the [puck prioir tovery move.
 Accelaration, speed and distance are provided via configuartion parameters.
*                       INCLUDES
#include <SerialCommand.h>
#include <StepControl.h>
#include <EEPROM.h>
//#include <Adafruit_ILI9341_AS.h>
//#include "StepControl.h"
*                       DEFINES
*                       GLOBALS
*                       VARIABLES
*                       CLASS DEFINES
SerialCommand SCmd;
************************ PROGRAM ***********************
Stepper motor(4, 5);
StepControl<> controller;
constexpr int spr = 16 * 200;  // 3200 steps per revolution
constexpr int dpr = 200;  // mm's per revolution
#define leftLimitSw 6
#define rightLimitSw 7
#define leftGoButton 8
#define rightGoButton 9
boolean leftHomeStatus;
boolean rightHomeStatus;
					homeLeft
Parameters:
int speed
Description: homes the puck to the left axis and
			 returns the status
Returns: leftHomeStatus
boolean homeLeft(int speed)
	return(leftHomeStatus);
					rightHome
Parameters:
int speed
Description: homes the puck to the right axis
Returns: rightHomeStatus
boolean rightHome(int speed)
	return(rightHomeStatus);
					travelRight
Parameters:
void
Description: move the puck to the right axis
Return: None
void travelRight(void)
					travelLeft
Parameters:
 void
Description: move the puck to left axis
Return: None
void travelLeft( void)
	motor
		.setMaxSpeed(2000)
		.setAcceleration(2500)
		.setStepPinPolarity(0)
		.setPullInSpeed(1000)
		.setPosition(0);
		/* add setup code here */
		// Setup callbacks for SerialCommand commands
	SCmd.addCommand("G", SetGroupId);
	//SCmd.addCommand("M", SetMasterId);
	//SCmd.addCommand("S", SetSlaveId);
	//SCmd.addCommand("C", GetCurrentConfig);
	//	  //SCmd.addCommand("P",process_command);  // Converts two arguments to integers and echos them back
	//SCmd.addDefaultHandler(unrecognized);  // Handler for command that isn't matched  (says "What?")
	SCmd.readSerial();
  /* add main program code here */
void SetGroupId()
	int aNumber;
	char *arg;
	arg = SCmd.next();
	if (arg != NULL)
		aNumber = atoi(arg);    // Converts a char string to an integer
		Serial.print(F("Group Id was set to: "));
		Serial.println(arg);
		////config.Group = aNumber;
		////EEPROM.put(eePromAdd, config);
		////PrintConfig();
		Serial.println(F("No arguments"));
	PrintMenu();
// This gets set as the default handler, and gets called when no other command matches.
void unrecognized()
	PrintMenu();
void PrintMenu(void)
	Serial.println("************ Setup Menu **************");
	Serial.print(F("Group Id = ")); Serial.println(F("'G'  ID  {numeric}"));
	Serial.print(F("Mater Id = ")); Serial.println(F("'M'  ID  {numeric}"));
	Serial.print(F("Slave Id = ")); Serial.println(F("'S'  ID  {numeric}"));
	Serial.print(F("Config   = ")); Serial.println(F("'C'"));
	Serial.println(F("G or M or S followed by space and a number or C for configuration"));
	Serial.print(F("Enter Selection ->> "));
These are the files I am using. I am not sure if they are the same as the library link I supplied.
SerialCommand.cpp (6.29 KB)
SerialCommand.h (5.75 KB)
You have some kind of disconnect with your libraries. The .h file you attached shows this as the prototype for ‘addCommand()’:
but later defines the callback structure thusly:
In one the callback function does not take an argument, in the other it does.
I see that and there seem to be a number of other discrepancies. I don't know if I somehow got my hands on a WIP library.
I am downloading the Aduino-SerialCommand version of the library now and start from scratch.
plz fix this.
no matching function for call to 'SerialCommand::addCommand(const char [2], void (&)())
Ruhullah:
plz fix this.
You want us to fix coe you broke, without seeing it? Not a chance.
