SerialCommand::addCommand() error
Im using ESP8266 for receiving data from uno r3 UART. I have tried many SerialCommand libraries but they all give me error.
exit status 1
no matching function for call to 'SerialCommand::addCommand(const char&, void (&)())'
Here is the error code:
  Serial.begin(9600);  //Khởi tạo cổng serial
  SCmd.addCommand("CAMBIEN1_VAL",  Relay1);
void Relay1() {
  int value_nhan;
  char *arg;
  arg = SCmd.next();
  value_nhan = atoi(arg);   // Converts a char string to an integer
  vall = atoi(arg); //chuyen chuoi thanh so
  if (val == 0) {
    digitalWrite(relay1, HIGH);//kich muc cao
    delay(10);
    Serial.println("Relay 1 OFF !");
    if (client.connect(ip_host, port)) {
      String req_uri = "/update?temp=" + String("May1_ON");
      client.print("GET " + req_uri + " HTTP/1.1\n" + "Host: " + ip_host + "\n" + "Connection: close\n" + "Content-Length: 0\n" + "\n\n");
    client.stop();
    delay(sendingInternval);
  else if (val == 1) {
    digitalWrite(relay1, LOW);//kich muc thap
    Serial.println("Ralay 1 ON !");
      String req_uri = "/update?temp=" + String("May1_OFF");
    client.stop();
    delay(100);
please help me <3
Please list them. If you downloaded them from the Internet, then provide the link. If you installed them via the Arduino Library Manager, then provide the full and exact name as shown in Library Manager.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. If you don't still have the IDE or web editor open with the error present, repeat the process that generated it.
  2. You now need to copy the full and exact text of the output. The procedure for doing this is different depending on which Arduino development software you are using:
    • Arduino IDE 1.x: Click the Copy error messages button on the right side of the orange bar in the IDE.
    • Arduino IDE 2.x: Right click on the black "Output" pane at the bottom of the IDE window and then select Copy All from the context menu.
    • Arduino Web Editor: Click the icon that looks like two pieces of paper at the top right corner of the black console window Web Editor.
  3. Open a forum reply here by clicking the Reply button.
  4. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  5. Press Ctrl+V. This will paste the compilation output into the code block.
  6. Move the cursor outside of the code block markup before you add any additional text to your reply.
  7. Click the Reply button to post the output.
Please tell us where you found the code that gave you the impression you could do this.
I added both these libraries from github:
and
GitHub - kroimon/Arduino-SerialCommand: A Wiring/Arduino library to tokenize and parse commands received over a serial port.
This is full Error messages:
Arduino: 1.8.15 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
D:\ArdE\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\ArdE\Arduino\hardware -hardware C:\Users\anhki\AppData\Local\Arduino15\packages -tools D:\ArdE\Arduino\tools-builder -tools D:\ArdE\Arduino\hardware\tools\avr -tools C:\Users\anhki\AppData\Local\Arduino15\packages -built-in-libraries D:\ArdE\Arduino\libraries -libraries C:\Users\anhki\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10815 -build-path D:\ArdE\HEX -warnings=none -build-cache C:\Users\anhki\AppData\Local\Temp\arduino_cache_861808 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino
D:\ArdE\Arduino\arduino-builder -compile -logger=machine -hardware D:\ArdE\Arduino\hardware -hardware C:\Users\anhki\AppData\Local\Arduino15\packages -tools D:\ArdE\Arduino\tools-builder -tools D:\ArdE\Arduino\hardware\tools\avr -tools C:\Users\anhki\AppData\Local\Arduino15\packages -built-in-libraries D:\ArdE\Arduino\libraries -libraries C:\Users\anhki\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10815 -build-path D:\ArdE\HEX -warnings=none -build-cache C:\Users\anhki\AppData\Local\Temp\arduino_cache_861808 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Using core 'esp8266' from platform in folder: C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Detecting libraries used...
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o nul
Alternatives for SerialCommand.h: [SerialCommand@2.0.1 ArduinoSerialCommand-master]
ResolveLibrary(SerialCommand.h)
  -> candidates: [SerialCommand@2.0.1 ArduinoSerialCommand-master]
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [WiFi@1.2.7 ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
  -> candidates: [WiFi@1.2.7 ESP8266WiFi@1.0]
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o nul
Alternatives for WebSocketsClient.h: [arduinoWebSockets-master@2.3.6]
ResolveLibrary(WebSocketsClient.h)
  -> candidates: [arduinoWebSockets-master@2.3.6]
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src\\SerialCommand.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGratuitous.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA-WPS.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiScan.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureBearSSL.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureBearSSL.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\enable_wifi_at_boot_time.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\SocketIOclient.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\WebSockets.cpp" -o nul
Alternatives for Hash.h: [Hash@1.0]
ResolveLibrary(Hash.h)
  -> candidates: [Hash@1.0]
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\WebSockets.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\WebSocketsClient.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\WebSocketsServer.cpp" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\libb64\\cdecode.c" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\libb64\\cencode.c" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src\\libsha1\\libsha1.c" -o nul
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src\\Hash.cpp" -o nul
Generating function prototypes...
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o "D:\\ArdE\\HEX\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"D:\\ArdE\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "D:\\ArdE\\HEX\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" "C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/signing.py" --mode header --publickey "C:\\Users\\anhki\\Documents\\Arduino\\UART_Esp/public.key" --out "D:\\ArdE\\HEX/core/Updater_Signing.h"
"C:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-ID:\\ArdE\\HEX/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10815 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\SerialCommand\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\anhki\\Documents\\Arduino\\libraries\\arduinoWebSockets-master\\src" "-IC:\\Users\\anhki\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\Hash\\src" "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp" -o "D:\\ArdE\\HEX\\sketch\\UART_Esp.ino.cpp.o"
C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino: In function 'void setup()':
UART_Esp:48:44: error: no matching function for call to 'SerialCommand::addCommand(const char&, void (&)())'
   48 |   SCmd.addCommand(*"CAMBIEN1_VAL", * Relay1);    //Nhận lệnh "LED"
In file included from C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino:1:
C:\Users\anhki\Documents\Arduino\libraries\SerialCommand\src/SerialCommand.h:67:10: note: candidate: 'void SerialCommand::addCommand(char*, void (*)(), void (*)(), void (*)(), void (*)())'
   67 |     void addCommand(char *cmd, void (*test)(), void (*read)(), void (*write)(), void (*execute)());
C:\Users\anhki\Documents\Arduino\libraries\SerialCommand\src/SerialCommand.h:67:10: note:   candidate expects 5 arguments, 2 provided
C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino: In function 'void loop()':
UART_Esp:65:8: error: 'class SerialCommand' has no member named 'readSerial'; did you mean 'readString'?
   65 |   SCmd.readSerial();
      |        readString
C:\Users\anhki\Documents\Arduino\UART_Esp\UART_Esp.ino: In function 'void Relay1()':
UART_Esp:73:3: error: 'vall' was not declared in this scope
   73 |   vall = atoi(arg); //chuyen chuoi thanh so
UART_Esp:74:7: error: 'val' was not declared in this scope
   74 |   if (val == 0) {
Multiple libraries were found for "SerialCommand.h"
 Used: C:\Users\anhki\Documents\Arduino\libraries\SerialCommand
 Not used: C:\Users\anhki\Documents\Arduino\libraries\ArduinoSerialCommand-master
Multiple libraries were found for "ESP8266WiFi.h"
 Used: C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi
 Not used: D:\ArdE\Arduino\libraries\WiFi
Using library SerialCommand at version 2.0.1 in folder: C:\Users\anhki\Documents\Arduino\libraries\SerialCommand
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi
Using library arduinoWebSockets-master at version 2.3.6 in folder: C:\Users\anhki\Documents\Arduino\libraries\arduinoWebSockets-master
Using library Hash at version 1.0 in folder: C:\Users\anhki\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\Hash
exit status 1
I searched for the answer a lot before asking the question in the Forum.
but are no results.
