Hello all, I've problems with the serial communication between my Arduino Leonardo and my PC. My C# program can not receive data in text box send by arduino.
here my sketch code
Serial.println("1111111");
C# Code
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
namespace WindowsFormsApplication4
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
updatePorts(); //Call Update COMPORT
private void updatePorts() //COMPORT UPDATE FUCNTION
string[] ports = SerialPort.GetPortNames();
foreach (string port in ports)
_comBox1.Items.Add(port);
private SerialPort ComPort = new SerialPort(); // Initial Comport variable
private void connect()
bool error = false;
//Check All
if(_comBox1.SelectedIndex != -1 & _buadRate.SelectedIndex != -1)
{ //If Currect
ComPort.Handshake = Handshake.RequestToSend;
ComPort.DtrEnable = true;
ComPort.RtsEnable = true;
ComPort.PortName = _comBox1.Text;
ComPort.BaudRate = int.Parse(_buadRate.Text);
ComPort.Parity = Parity.None;
ComPort.DataBits = 8;
ComPort.StopBits = StopBits.One;
try
ComPort.Open();
catch (UnauthorizedAccessException) { error = true; }
catch (System.IO.IOException) { error = true; }
catch (ArgumentException) { error = true; }
if (error) MessageBox.Show(this, "Could not open the Com port. Maybe is already in use, has been removed, or is unavailable.", "Com port unavailable", MessageBoxButtons.OK, MessageBoxIcon.Stop);
MessageBox.Show("Please select COM Port Settings", "Serial Port Interface", MessageBoxButtons.OK, MessageBoxIcon.Stop);
//If the port open, change the connect button to disconnect enable the send button.
//Disable the groupBox to prevent changing configuration of an open port.
if (ComPort.IsOpen)
_conBUTT.Text = "Disconnect";
//_sendBUTT.Enabled = true;
groupBox1.Enabled = false;
private void disconnect()
ComPort.Close();
_conBUTT.Text = "Connect";
//_sendBUTT.Enabled = false;
groupBox1.Enabled = true;
private void _conBUTT_Click(object sender, EventArgs e)
if (ComPort.IsOpen)
disconnect();
connect();
private void Form1_FormClosing(object sender, FormClosedEventArgs e)
if (ComPort.IsOpen) ComPort.Close();
private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
string recievedData = serialPort1.ReadExisting();
_rtbData.AppendText(recievedData);
Do I missing something in my C# code??. Thank you
