Hello all, I've problems with the serial communication between my Arduino Leonardo and my PC. I've developed a C# program which interfaces with my Arduino.
The C#~program writes perfectly in the serial interface. Then the Arduino reads this communication and puts a HIGH or a LOW level in a digital output. However it does not receive the data sent by the Arduino ![]()
I've checked that the Arduino sends the data propperly, both using the Serial monitor in the Arduino Environment, and Hyperterminal in my PC. Hyperterminal reads perfectly the strings sent by Arduino.
I've used the class SerialPort. I use a SerialDataReceivedEventHandler to process the data received through the serial port. This event is never activated so this handler function is never executed...
I've read in internet that it is necessary to use an independent thread to read the serial port. I thought that using this handler was enough... is not?
I also used a different program available in internet, with the same result. I could write to Arduino, but not read. The program is available in the site http://msmvps.com/blogs/coad/archive/2005/03/23/SerialPort-_2800_RS_2D00_232-Serial-COM-Port_2900_-in-C_2300_-.NET.aspx
Here is my code:
Form1.cs
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports; // Serial port
//using System.Threading;
namespace PruebasArduino02
public partial class Form1 : Form
// Timer para la comunicación serie
System.Windows.Forms.Timer ComTimer = new System.Windows.Forms.Timer();
// The main control for communicating through the RS-232 port
private SerialPort comport = new SerialPort();
public Form1()
InitializeComponent();
comport.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived);
private void Form1_Load(object sender, EventArgs e)
comport.PortName = "COM12";
comport.BaudRate = Convert.ToInt16(9600);
comport.Open();
ComTimer.Tick += new EventHandler(TimerFcn);
ComTimer.Interval = 2000;
//ComTimer.Start();
private void TimerFcn(Object myObject, EventArgs myEventArgs)
label1.Text = "Hello";
//serialPort1.Open();
//label1.Text = serialPort1.ReadLine().ToString();
//serialPort1.Close();
private void button1_Click(object sender, EventArgs e)
comport.Write("1");
private void button2_Click(object sender, EventArgs e)
comport.Write("0");
private void port_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
// Read all the data waiting in the buffer
string data = comport.ReadExisting();
// Display the text to the user in the terminal
Log(data);
private void Log(string msg)
label1.Invoke(new EventHandler(delegate
label1.Text = msg;
Form1.Designer.cs
partial class Form1
/// Variable del diseñador requerida.
private System.ComponentModel.IContainer components = null;
/// Limpiar los recursos que se estén utilizando.
/// true si los recursos administrados se deben eliminar; false en caso contrario, false.
protected override void Dispose(bool disposing)
if (disposing && (components != null))
components.Dispose();
base.Dispose(disposing);
#region Código generado por el Diseñador de Windows Forms
/// Método necesario para admitir el Diseñador. No se puede modificar
/// el contenido del método con el editor de código.
private void InitializeComponent()
this.button1 = new System.Windows.Forms.Button();
this.button2 = new System.Windows.Forms.Button();
this.label1 = new System.Windows.Forms.Label();
this.SuspendLayout();
// button1
this.button1.Location = new System.Drawing.Point(53, 70);
this.button1.Name = "button1";
this.button1.Size = new System.Drawing.Size(75, 23);
this.button1.TabIndex = 0;
this.button1.Text = "button1";
this.button1.UseVisualStyleBackColor = true;
this.button1.Click += new System.EventHandler(this.button1_Click);
// button2
this.button2.Location = new System.Drawing.Point(163, 112);
this.button2.Name = "button2";
this.button2.Size = new System.Drawing.Size(75, 23);
this.button2.TabIndex = 1;
this.button2.Text = "button2";
this.button2.UseVisualStyleBackColor = true;
this.button2.Click += new System.EventHandler(this.button2_Click);
// label1
this.label1.AutoSize = true;
this.label1.Location = new System.Drawing.Point(118, 180);
this.label1.Name = "label1";
this.label1.Size = new System.Drawing.Size(35, 13);
this.label1.TabIndex = 2;
this.label1.Text = "label1";
this.label1.TextAlign = System.Drawing.ContentAlignment.MiddleCenter;
// Form1
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
this.ClientSize = new System.Drawing.Size(292, 266);
this.Controls.Add(this.label1);
this.Controls.Add(this.button2);
this.Controls.Add(this.button1);
this.Name = "Form1";
this.Text = "Form1";
this.Load += new System.EventHandler(this.Form1_Load);
this.ResumeLayout(false);
this.PerformLayout();
#endregion
private System.Windows.Forms.Button button1;
private System.Windows.Forms.Button button2;
private System.Windows.Forms.Label label1;
Program in Arduino Leonardo
pinMode(2, INPUT_PULLUP); // not used
pinMode(13, OUTPUT);
char incomingChar;
int buttonState = digitalRead(2); // not used
if(Serial.available() > 0)
incomingChar = Serial.read();
switch(incomingChar){
case '1':
// led is ON
digitalWrite(13, HIGH);
case '0':
// led is OFF
digitalWrite(13, LOW);
delay(10);
if(1)
Serial.println("Hello!\n");
delay(10);
Do you have any idea? I'm getting crazy with this issue... Thank you in advance! ![]()
