Wawa
October 28, 2022, 8:01am
1
Just upgraded to 2.0.1
How do you put the serialmonitor into 74880 baud rate (needed to see ESP8266 boot data).
How do you open a separate serial window (only serialplotter seems to be able to do that).
Do I have to give up coding space for a permanently attached serial monitor?
That's two issues I ran into within five minutes. There might be more.
Might as well go back to an older version.
Leo..
Hi @Wawa
Unfortunately at this time there is no way to do this. The deficiency is being tracked by the Arduino IDE developers here:
opened 03:07PM - 24 Jun 20 UTC
closed 02:35PM - 09 Jan 23 UTC
type: imperfection
conclusion: resolved
topic: code
### Describe the request
Compared to legacy IDE's serial monitor, it would be… nice to get the "extra" baudrate like 230400, 250000, 500000, 1000000, and 2000000.
### Describe the current behavior
**serial-monitor** does not offer the option of some useful baudrates.
### Additional context
Additional requests:
- https://github.com/arduino/Arduino/issues/4439
- https://github.com/arduino/Arduino/issues/3879
- https://github.com/arduino/Arduino/issues/356
- https://github.com/arduino/Arduino/issues/142
There is no option for a dedicated Serial Monitor window as in Arduino IDE 1.x. The workaround would be to use File > New to open another Arduino IDE window and use that window solely for Serial Monitor, with the other window used for sketch development.
The Arduino IDE developers are tracking the need to change Serial Monitor to being a separate window like Serial Plotter here:
opened 07:48PM - 29 Mar 21 UTC
type: enhancement
topic: code
topic: serial monitor
Allow **Serial Monitor** to be placed in a dedicated w… indow separate from the primary Arduino IDE window.
🙂 It will be possible for the user to control the display location of the Serial Monitor separately from the primary Arduino IDE window according to their needs and preferences.
🙂 This will provide feature parity with the Arduino IDE 1.x Serial Monitor.
Serial Monitor is a view in the bottom panel of the primary Arduino IDE window.
🙁 It is not possible to move Serial Monitor to a separate screen in order to dedicate all space on the primary screen to the Arduino IDE editor.
### Arduino IDE version
#### Original report
2.0.0-beta.4
#### Last verified with
2.0.1-snapshot-32d904c
### Operating system
All
### Operating system version
Any
The requested "tear off" capability would probably make sense for other windows ("**Output**" view) too.
<a name="workaround"></a>
#### Workaround
1. Select **File > New Sketch** from the Arduino IDE menus.
A new Arduino IDE window will open.
1. Select **Tools > Serial Monitor** from the Arduino IDE menus.
The "**Serial Monitor**" view will open in the bottom panel of the Arduino IDE window.
1. Hover the mouse pointer over the top border of the bottom panel.
The mouse pointer will change into a resize icon.
1. Click and drag the border up until it reaches its maximum height.
You can now use that Arduino IDE window solely for Serial Monitor, switching back to the other Arduino IDE window to do sketch editing, compile, upload, etc. operations just as you would do with the Arduino IDE 1.x Serial Monitor.
#### Additional requests
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-810073157
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-813597014
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-850550857
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-983961342
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1006024396
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1034829176
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1068087883
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1195300991
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1247730828
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1247930105
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1257039691
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1382677544
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1399304977
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1399421191
- https://github.com/arduino/arduino-ide/issues/1799
- https://github.com/arduino/arduino-ide/issues/1268
- https://github.com/arduino/arduino-ide/issues/755
- https://github.com/arduino/arduino-ide/issues/2131
- https://www.facebook.com/official.arduino/posts/pfbid02x5KM54Gf7L56Tea79pLYVafrciYAGZrioedDVD6YFKEnJdsiNT3w6S2WinZtrAc9l?comment_id=1395510504579311
- https://www.facebook.com/official.arduino/posts/pfbid02qWaAtdLM6Hz43h7BRiYLg3yAoDz4HXRw28tLpgc4d1rszqG5gjbbumA21cLcS2Vcl?comment_id=996845494967736
- https://twitter.com/DevReliefFred/status/1696610597171773571
- https://twitter.com/PaulStoffregen/status/1658089036685410305
- https://forum.arduino.cc/t/making-the-serial-console-a-dockable-screen-again/1079586
- https://forum.arduino.cc/t/ide-2-0-3-undocking-serial-monitor/1063170
- https://forum.arduino.cc/t/arduino-ide-usb-serial-terminal-issues/1049458/13
- https://forum.arduino.cc/t/how-to-get-all-my-1-18-19-libraries-installed-in-2-0-1/1050248/3
- https://forum.arduino.cc/t/serialmonitor-74880-baud-rate-in-ide-2-0-1/1046886
- https://forum.arduino.cc/t/windows-the-serial-monitor-window-needs-to-pop-out-please/1036538
- https://forum.arduino.cc/t/using-v-2-0-serial-monitor-print/1034093
- https://forum.arduino.cc/t/arduino-2-0-0-macos-unexpected-differences/1033549
- https://forum.arduino.cc/t/2-0-keyboard-shortcuts-dont-work/1033105/11
- https://forum.arduino.cc/t/arduino-ide-2-0-0-available-for-download/1031651/17
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/1
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/3
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/4
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/15
- https://forum.arduino.cc/t/changing-ide-fonts/1028827
- https://forum.arduino.cc/t/serial-monitor-issues-hopefully-fixed-before-release/1026548
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/1
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/2
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/5
- https://forum.arduino.cc/t/automatic-build-external-screen-for-serial/1013958
- https://forum.arduino.cc/t/serial-monitor-with-new-ide/1010684/10
- https://forum.arduino.cc/t/ide-2-0-rc5-serial-monitor-problems/978293
- https://forum.arduino.cc/t/serial-monitor-characteristics-fail/943590
- https://forum.arduino.cc/t/how-to-dock-serial-monitor/942477
- https://forum.arduino.cc/t/how-to-dock-serial-monitor/942477/12
- https://forum.arduino.cc/t/no-support-for-esp32-boards-manager-2-01/940115/5
- https://forum.arduino.cc/t/first-impressions-and-comments/930873
- https://forum.arduino.cc/t/missing-serial-monitor-and-serial-plotter/924262
- https://forum.arduino.cc/t/arduino-2-0-has-too-many-problems/1100602
- https://forum.arduino.cc/t/arduino-2-0-has-too-many-problems/1100602/13
- https://forum.arduino.cc/t/missing-baud-rate-dropdown-v2-0-4-ide/1105972
- https://forum.arduino.cc/t/arduino-2-04-stuck-in-splash-screen/1107587/11
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/16
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/17
- https://forum.arduino.cc/t/serial-monitor-double-window-problem/1112463
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/18
- https://forum.arduino.cc/t/ide-2-1-i-am-not-happy/1142471
- https://forum.arduino.cc/t/ide-2-serial-monitor/1146303
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/26
- https://forum.arduino.cc/t/i-miss-my-separate-serial-monitor-window/1163606
- https://forum.arduino.cc/t/cannot-upload-to-ftdi-megas-only/1170683
- https://forum.arduino.cc/t/your-reason-for-not-switching-to-the-2-x-ide/1176322
- https://forum.arduino.cc/t/your-reason-for-not-switching-to-the-2-x-ide/1176322/23
- https://forum.arduino.cc/t/serial-monitor-in-separate-window-larger-font-etc/1204423
- https://forum.arduino.cc/t/adios-ide-2-0-this-is-goodbye-forever/1031455/46
- https://forum.arduino.cc/t/undock-serial-monitor/1237489
- https://forum.arduino.cc/t/serial-monitor-not-in-separate-window-now/1299502/4
- https://forum.arduino.cc/t/feeback-on-latest-2-x-ide-w-win11/1333594
- https://forum.arduino.cc/t/critical-flaws-in-v2-ide/1335245
- https://forum.arduino.cc/t/several-bugs-in-ide/1361018/11
- https://forum.arduino.cc/t/path-error-linux-22-1/1393509/4
- https://forum.arduino.cc/t/output-window-format/1406883
#### Related
- https://forum.arduino.cc/t/can-we-pin-the-serial-plotter-window-in-ide-2-x/1415954
### Issue checklist
- [X] I searched for previous requests in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the feature was still missing when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My request contains all necessary details
As explained, you do have the option to use a separate Arduino IDE window for that. Something I should point out, since some find it to be non-obvious, is that you can click the icon at the bottom right corner of the Arduino IDE window ("Toggle Bottom Panel ") to hide the bottom panel. So it doesn't need to take up coding space always.
Wawa:
Please do let us know if you find any problems or have any feedback.
I'm sorry if Arduino IDE 2.x did not meet your requirements. If you look at the changelog for 2.0.1, you will see the project is still under very active development:
If you are using a recent version of the IDE, you will get an auto-update offer simply by starting the IDE.
Otherwise, the release is available for download here:
https://www.arduino.cc/en/software
This release provides some nice advancements and fixes.
Thanks so much to the forum community for all the valuable testing and feedback that has helped us greatly in identifying and investigating these bugs and enhancements!
Use Enter as Serial Monitor keyboard send trigger
arduino/arduino-ide#1…
So we can hope that in time the deficiencies impactful to you will be resolved.
If you have a GitHub account, you can subscribe to the issues of interest to get notifications of any new developments related to this subject.
Wawa
October 28, 2022, 6:27pm
3
You're saying: Keep using 2.0.1 untill the problems are fixed?
Because if I don't use it, how will I see if the problems are fixed.
Sorry, can't do that.
An integrated serial moitor peephole might be ok for someone on a laptop or tablet,
but it seems totally unworkable after you have been using 1.8.19 on a widescreen monitor.
Both issues I mentioned are known for about two years now.
I don't see that they will be resolved soon.
Back to 1.8.19. Much better. Will try again in another two years or so.
Leo..
Didn't tell you what to do either way. Do as you like.
As I already said, subscribe to the GitHub issues. They will be closed when the developers have resolved the issue.
system
Closed
April 26, 2023, 8:04pm
5
