Servo actioned by RFID to toggle with a switch
I have the below code that "opens" a servo with the scanning of the correct RFID and "locks" again on the push of a button.
What I am needing to do is have the same button able to "lock" is open and open if locked.
Obviously the servo may be in either position depending on whether the last action was done via the RFID tag.
I hope this make sense
Any thoughts?
  Arduino Door Lock Access Control Project
  by Dejan Nedelkovski, www.HowToMechatronics.com
  Library: MFRC522, https://github.com/miguelbalboa/rfid
#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#define RST_PIN   9
#define SS_PIN    10
int LED = A0;
int BUTTON = A1;
byte readCard[4];
char* myTags[100] = {};
int tagsCount = 0;
String tagID = "";
boolean successRead = false;
boolean correctTag = false;
//int proximitySensor;
//boolean doorOpened = false;
// Create instances
MFRC522 mfrc522(SS_PIN, RST_PIN);
LiquidCrystal lcd(7, 6, 5, 4, 3, 2); //Parameters: (rs, enable, d4, d5, d6, d7)
            // it's a 16x2 LCD so...
            int screenWidth = 20;
            int screenHeight = 4;
            // line1 = scrolling
            String line1 = " Acedemic Support Section   Enter At Your Own Risk!!! "; //Edit  scrolling message
            // just some reference flags
            int stringStart, stringStop = 0;
            int scrollCursor = screenWidth;
Servo myServo; // Servo motor
// Initialize Pins for led's, servo and buzzer
// Blue LED is connected to 5V
constexpr uint8_t greenLed = A4;
constexpr uint8_t redLed = A3;
  // Initiating
  SPI.begin();        // SPI bus
  mfrc522.PCD_Init(); //  MFRC522
  lcd.begin(20, 4);   // LCD screen
  myServo.attach(8);  // Servo motor
  myServo.write(00); // Initial lock position of the servo motor
  // Prints the initial message
  lcd.print("-No Master Tag!-");
  lcd.setCursor(0, 1);
  lcd.print("    SCAN NOW");
  // Waits until a master card is scanned
  while (!successRead) {
    successRead = getID();
    if ( successRead == true) {
      myTags[tagsCount] = strdup(tagID.c_str()); // Sets the master tag into position 0 in the array
      lcd.clear();
      lcd.setCursor(2, 0);
      lcd.print("Master Tag Set!");
      tagsCount++;
  printNormalModeMessage();
    pinMode(A0, OUTPUT);
    pinMode (A1, INPUT);
    pinMode(A2, OUTPUT);
 ScrollMessage();
  { //Lock Door
    if (digitalRead(A1) == HIGH)
    { digitalWrite(A2, HIGH); //Switch on power to the servo
      delay(3000);    //Lock delay
      myServo.write(0);   //Reset Servo
      digitalWrite(greenLed, LOW);
      digitalWrite(redLed, HIGH); //Set Red Locked LED
      delay(3000);
      digitalWrite(A2, LOW); //Switch off power to the servo
// Set master card and add or remove tags
  if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
    return;
  if ( ! mfrc522.PICC_ReadCardSerial()) {   //Since a PICC placed get Serial and continue
    return;
  tagID = "";
  // The MIFARE PICCs that we use have 4 byte UID
  for ( uint8_t i = 0; i < 4; i++) {  //
    readCard[i] = mfrc522.uid.uidByte[i];
    tagID.concat(String(mfrc522.uid.uidByte[i], HEX)); // Adds the 4 bytes in a single String variable
  tagID.toUpperCase();
  mfrc522.PICC_HaltA(); // Stop reading
  correctTag = false;
  // Checks whether the scanned tag is the master tag
  if (tagID == myTags[0]) {
    lcd.clear();
    lcd.print("Program mode:");
    lcd.print("Add/Remove Tag");
        for (int i = 0; i < 100; i++) {
          if (tagID == myTags[i]) {
            myTags[i] = "";
            lcd.clear();
            lcd.setCursor(0, 0);
            lcd.print("  Tag Removed!");
            return;
        lcd.clear();
        lcd.print("   Tag Added!");
        tagsCount++;
        return;
  // Checks whether the scanned tag is authorized
      lcd.clear();
      lcd.print(" Access Granted!");
      myServo.write(170); // Unlocks the door
      delay(3000);
      digitalWrite(greenLed, HIGH);
      digitalWrite(A0, LOW);
//      delay(3000);
//      digitalWrite(greenLed, LOW);
      //        myServo.write(0);
      correctTag = true;
  if (correctTag == false) {
    lcd.clear();
    lcd.print(" Access Denied!");
    digitalWrite(redLed, LOW);
uint8_t getID() {
  // Getting ready for Reading PICCs
    return 0;
    return 0;
  tagID = "";
  for ( uint8_t i = 0; i < 4; i++) {  // The MIFARE PICCs that we use have 4 byte UID
  return 1;
void printNormalModeMessage() {
  delay(1500);
  lcd.clear();
  lcd.print("  -Access Control-");
  lcd.print("      Scan Tag");
void ScrollMessage() {
            lcd.setCursor(scrollCursor, 3);
            lcd.print(line1.substring(stringStart,stringStop));
//            lcd.setCursor(0, 0);
           // lcd.print(line2);
            delay(300);
//            lcd.clear();
            if(stringStart == 0 && scrollCursor > 0){
              scrollCursor--;
              stringStop++;
            } else if (stringStart == stringStop){
              stringStart = stringStop = 0;
            } else if (stringStop == line1.length() && scrollCursor == 0) {
              stringStart++;
              stringStart++;
              stringStop++;
So just keep a global flag to tell you if it's locked or open. Then just write the reverse when the button is pressed.
If you don't want a separate flag you could always use servo.read() to tell you where the servo is now.
But I'd like to see a circuit diagram of this. I'm a bit worried about all that using pin A2 to "switch power to the servo". Switch the power off and the servo can easily be moved which doesn't sound like what you want for a lock.
Steve
