Description: Model Rocket motor gimbal using 2 servo. This is yet again another attempt to fly a model rocket without fins using long burn motors.
It is using the Arduino PID controler to move a rocket motor.
Angle changes can be monitored using a USB cable or a bluetooth interface
Inspired by various camera gimbal projects
Sensor used is an MPU6050 board
Servo Connection
BROWN - gnd
red - 5v either on extension prototyping board or on original arduino board for UNO.
yellow - D10 (pwm for Sero X)
- D11 (servo Y)
MPU6050 board Connections
VCC - 5v
GND - GND
SCL - A5 or pin SCL on the stm32
SDA - A4 or pin SDA on the stm32
INT - D2 (not used)
LINE 80 = PID tuning for both x perameters and y parameters
#include <Servo.h> //servo library
#include <I2Cdev.h>
#include <MPU6050_6Axis_MotionApps20.h> // Gyroscope and axcelerometer libraries
#include <PID_v1.h> // Arduino PID library
#include <Wire.h>
#define LED_PIN 13 //pin 13 for the arduino Uno and PC13 for the stm32
bool blinkState = true;
Servo ServoX; // X axis Servo
Servo ServoY; // Y axis Servo
float mpuPitch = 0;
float mpuRoll = 0;
float mpuYaw = 0;
// Create MPU object
// class default I2C address is 0x68; specific I2C addresses may be passed as a parameter here
// for exemple MPU6050 mpu(0x69);
MPU6050 mpu;
// MPU control/status vars
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// relative ypr[x] usage based on sensor orientation when mounted, e.g. ypr[PITCH]
#define PITCH 1 // defines the position within ypr[x] variable for PITCH; may vary due to sensor orientation when mounted
#define ROLL 2 // defines the position within ypr[x] variable for ROLL; may vary due to sensor orientation when mounted
#define YAW 0 // defines the position within ypr[x] variable for YAW; may vary due to sensor orientation when mounted
// PID's
//Define Variables we'll be connecting to
double SetpointX, InputX, OutputX;
double SetpointY, InputY, OutputY;
// Those initial tuning parameters need to be tuned
// this a bit like when you tune your copter apart from the fact that the rocket motor last only few seconds
// PID TUNING HERE!!!
//double KpX = 2, KiX = 5, KdX = 1;
double KpX = 3.55, KiX = 0.005, KdX = 2.05;
//Specify the links and initial tuning parameters
//double KpY = 2, KiY = 5, KdY = 1;
double KpY = 3.55, KiY = 0.005, KdY = 2.05;
PID myPIDX(&InputX, &OutputX, &SetpointX, KpX, KiX, KdX, DIRECT);
PID myPIDY(&InputY, &OutputY, &SetpointY, KpY, KiY, KdY, DIRECT);
//calibration stuff
//Change those 3 variables if you want to fine tune the skecth to your needs.
int buffersize = 200; //Amount of readings used to average, make it higher to get more precision but sketch will be slower (default:1000)
int acel_deadzone = 8; //Acelerometer error allowed, make it lower to get more precision, but sketch may not converge (default:8)
int giro_deadzone = 1; //Giro error allowed, make it lower to get more precision, but sketch may not converge (default:1)
int16_t ax, ay, az, gx, gy, gz;
int mean_ax, mean_ay, mean_az, mean_gx, mean_gy, mean_gz, state = 0;
int ax_offset, ay_offset, az_offset, gx_offset, gy_offset, gz_offset;
Initial setup
do the board calibration
if you use the calibration function do not move the board until the calibration is complete
ServoX.attach(10); // attaches the X servo on PA1 for stm32 or D10 for the Arduino Uno
ServoY.attach(11); // attaches the Y servo on PA2 for stm32 or D11 for the Arduino Uno
// set both servo's to 90 degree
ServoX.write(90);
ServoY.write(90);
Wire.begin();
Serial.begin(230400);
while (!Serial); // wait for Leonardo enumeration, others continue immediately
// initialize device
Serial.println(F("Initializing MPU 6050 device..."));
mpu.initialize();
// verify connection
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
// load and configure the DMP
Serial.println(F("Initializing DMP"));
devStatus = mpu.dmpInitialize();
// INPUT CALIBRATED OFFSETS HERE; SPECIFIC FOR EACH UNIT AND EACH MOUNTING CONFIGURATION!!!!
// use the calibrate function for yours
// you can also write down your offset ans use them so that you do not have to re-run the calibration
ax_offset = 1118;
ay_offset = 513;
az_offset = 1289;
gx_offset = 64;
gy_offset = -1;
gz_offset = -33;
// configure LED for output
pinMode(LED_PIN, OUTPUT);
calibrate();
initialize();
void initialize() {
mpu.initialize();
mpu.setXAccelOffset(ax_offset);
mpu.setYAccelOffset(ay_offset);
mpu.setZAccelOffset(az_offset);
mpu.setXGyroOffset(gx_offset);
mpu.setYGyroOffset(gy_offset);
mpu.setZGyroOffset(gz_offset);
//turn the PID on
//servo's can go from 60 degree's to 120 degree so set the angle correction to + - 30 degrees max
myPIDX.SetOutputLimits(-30, 30);
myPIDY.SetOutputLimits(-30, 30);
myPIDX.SetMode(AUTOMATIC);
myPIDY.SetMode(AUTOMATIC);
SetpointX = 0;
SetpointY = 0;
// make sure it worked (returns 0 if so)
if (devStatus == 0)
// turn on the DMP, now that it's ready
Serial.println(F("Enabling DMP"));
mpu.setDMPEnabled(true);
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed, 2 = DMP configuration updates failed (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed code = "));
Serial.println(devStatus);
MAIN PROGRAM LOOP
void loop(void)
MainMenu();
//myloop();
void myloop(void)
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ( fifoCount == 1024)
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
return;
// check for correct available data length
if (fifoCount < packetSize)
return;
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
fifoCount -= packetSize;
// flush buffer to prevent overflow
mpu.resetFIFO();
// display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
mpuPitch = ypr[PITCH] * 180 / M_PI;
mpuRoll = ypr[ROLL] * 180 / M_PI;
mpuYaw = ypr[YAW] * 180 / M_PI;
mpu.resetFIFO();
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
mpu.resetFIFO();
InputX = mpuPitch;
myPIDX.Compute();
InputY = mpuRoll;
myPIDY.Compute();
//if using PID do those
ServoX.write(-OutputX + 90);
ServoY.write(OutputY + 90);
// if you do not want to use the PID
// ServoX.write(-mpuPitch + 90);
// ServoY.write(mpuRoll + 90);
float q1[4];
q1[0] = q.w;
q1[1] = q.x;
q1[2] = q.y;
q1[3] = q.z;
serialPrintFloatArr(q1, 4);
Serial.print(mpuPitch);
Serial.print(" ");
Serial.print(mpuRoll);
Serial.print(" ");
Serial.print(OutputX);
Serial.print(" ");
Serial.println(OutputY);
delay(10);
mpu.resetFIFO();
=== Those 2 functions will format the data ===
void serialPrintFloatArr(float * arr, int length) {
for (int i = 0; i < length; i++) {
serialFloatPrint(arr[i]);
Serial.print(",");
void serialFloatPrint(float f) {
byte * b = (byte *) &f;
for (int i = 0; i < 4; i++) {
byte b1 = (b[i] >> 4) & 0x0f;
byte b2 = (b[i] & 0x0f);
char c1 = (b1 < 10) ? ('0' + b1) : 'A' + b1 - 10;
char c2 = (b2 < 10) ? ('0' + b2) : 'A' + b2 - 10;
Serial.print(c1);
Serial.print(c2);
calibration routines those will be executed each time the board is powered up.
we might want to calibrate it for good on a flat table and save it to the microcontroler eeprom
void calibrate() {
// start message
Serial.println("\nMPU6050 Calibration Sketch");
//delay(1000);
Serial.println("\nYour MPU6050 should be placed in horizontal position, with package letters facing up. \nDon't touch it until you see a finish message.\n");
//delay(1000);
Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
//delay(1000);
// reset offsets
mpu.setXAccelOffset(0);
mpu.setYAccelOffset(0);
mpu.setZAccelOffset(0);
mpu.setXGyroOffset(0);
mpu.setYGyroOffset(0);
mpu.setZGyroOffset(0);
while (1) {
if (state == 0) {
Serial.println("\nReading sensors for first time...");
meansensors();
state++;
delay(100);
if (state == 1) {
Serial.println("\nCalculating offsets...");
calibration();
state++;
delay(100);
if (state == 2) {
meansensors();
Serial.println("\nFINISHED!");
Serial.print("\nSensor readings with offsets:\t");
Serial.print(mean_ax);
Serial.print("\t");
Serial.print(mean_ay);
Serial.print("\t");
Serial.print(mean_az);
Serial.print("\t");
Serial.print(mean_gx);
Serial.print("\t");
Serial.print(mean_gy);
Serial.print("\t");
Serial.println(mean_gz);
Serial.print("Your offsets:\t");
Serial.print(ax_offset);
Serial.print("\t");
Serial.print(ay_offset);
Serial.print("\t");
Serial.print(az_offset);
Serial.print("\t");
Serial.print(gx_offset);
Serial.print("\t");
Serial.print(gy_offset);
Serial.print("\t");
Serial.println(gz_offset);
Serial.println("\nData is printed as: acelX acelY acelZ giroX giroY giroZ");
Serial.println("Check that your sensor readings are close to 0 0 16384 0 0 0");
Serial.println("If calibration was succesful write down offsets so you can set them in your projects using something similar to mpu.setXAccelOffset(youroffset)");
//while (1);
void meansensors() {
long i = 0, buff_ax = 0, buff_ay = 0, buff_az = 0, buff_gx = 0, buff_gy = 0, buff_gz = 0;
while (i < (buffersize + 101)) {
// read raw accel/gyro measurements from device
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
if (i > 100 && i <= (buffersize + 100)) { //First 100 measures are discarded
buff_ax = buff_ax + ax;
buff_ay = buff_ay + ay;
buff_az = buff_az + az;
buff_gx = buff_gx + gx;
buff_gy = buff_gy + gy;
buff_gz = buff_gz + gz;
if (i == (buffersize + 100)) {
mean_ax = buff_ax / buffersize;
mean_ay = buff_ay / buffersize;
mean_az = buff_az / buffersize;
mean_gx = buff_gx / buffersize;
mean_gy = buff_gy / buffersize;
mean_gz = buff_gz / buffersize;
i++;
delay(2); //Needed so we don't get repeated measures
void calibration() {
ax_offset = -mean_ax / 8;
ay_offset = -mean_ay / 8;
az_offset = (16384 - mean_az) / 8;
gx_offset = -mean_gx / 4;
gy_offset = -mean_gy / 4;
gz_offset = -mean_gz / 4;
while (1) {
int ready = 0;
meansensors();
Serial.println("...");
if (abs(mean_ax) <= acel_deadzone) ready++;
else ax_offset = ax_offset - mean_ax / acel_deadzone;
if (abs(mean_ay) <= acel_deadzone) ready++;
else ay_offset = ay_offset - mean_ay / acel_deadzone;
if (abs(16384 - mean_az) <= acel_deadzone) ready++;
else az_offset = az_offset + (16384 - mean_az) / acel_deadzone;
if (abs(mean_gx) <= giro_deadzone) ready++;
else gx_offset = gx_offset - mean_gx / (giro_deadzone + 1);
if (abs(mean_gy) <= giro_deadzone) ready++;
else gy_offset = gy_offset - mean_gy / (giro_deadzone + 1);
if (abs(mean_gz) <= giro_deadzone) ready++;
else gz_offset = gz_offset - mean_gz / (giro_deadzone + 1);
if (ready == 6) break;
// Main menu to interpret all the commands sent by the altimeter console
void MainMenu()
char readVal = ' ';
int i = 0;
char commandbuffer[200];
while (Serial.available())
readVal = Serial.read();
if (readVal != ';' )
if (readVal != '\n')
commandbuffer[i++] = readVal;
commandbuffer[i++] = '\0';
if (commandbuffer[0] != '\0') {
interpretCommandBuffer(commandbuffer);
commandbuffer[0] = '\0';
myloop();
void interpretCommandBuffer(char *commandbuffer) {
//Serial1.println((char*)commandbuffer);
//this will erase all flight
if (commandbuffer[0] == 'c')
Serial.println(F("calibration\n"));
// Do calibration suff
state = 0;
calibrate();
