I built a laser pointer for clay shooting dry practicing.
I want it to draw straight line on the wall with a laser pointer (like the cat toys you see on YouTube) to follow with the laser pointer in the gun.
This works though there's one physics problem, the laser is pointing at an tilted angle so when starting the sweep it doesn't draw a horizontal line but instead it makes a Amazon logo.
I understand that this is because of the laser being rotated by the pan servo though I'd like to know if I can compensate this by using the tilt servo.
So when panning it should slightly tilt to bend the curve if that makes sense to you experts?
Setup is 2 servos mounted to each other for pan and tilt controlled by a Uno.
Best regards,
Added details, the servo is moving slowly so I'm able to follow the dot on the wall. About 2 seconds for 5 meters distance.
