I'm trying to power my servo but when powered using about 5.5v (they are rated from 4.75 - 6) the servo starts going like twitching back and forth - if I power it from the 5v on the arduino board it works fine. I tested using a multimeter and it is definitely 5.5v coming from the external power supply.
Please post the sketch that you are running, a schematic of your project and details of what the servo is connected to
There's no power to this setup. Why?
I had forgotten in that, but the servos are powered externally by 5.5v (and 5a) and the arduino is powered by the usb port (Not sure on the name)
Hello aarush41
My recommendation is to run a servo turorial to get started.
Is this part of those docs ?
for (pos = 0; pos <= -30; pos += 1)
What values will pos have ?
I am following https://docs.arduino.cc/learn/electronics/servo-motors, however there isn't anything wrong with the code but it seems like the power, when I plug in my external power supply it starts to twitch however when I plug the servo into the 5v on the arduino board it works fine.
The twitching behavior is almost always due to an inadequate servo power supply. Budget 1 Ampere per servo for small ones like SG-90, 2.5A per servo for larger ones link the MG996R.
Never use the Arduino 5V output for motors or servos, as that can damage the Arduino.
A 4xAA pack of fresh alkaline cells will work for 1-2 small servos. Don't forget to connect the grounds!
Here is the for loop for the Sweep example on that page
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
Compare it with your for loop
What values will pos have in your sketch ?
That is because you do not have the - on the external power connected to the ground on your Arduino.
Thank you, this worked - I had assumed that I would just plug the - straight to the servo.
What about the for loop ?
