Servo issues with ESP32servo
Good morning all,
I have been fiddling about trying to use this library for servo control functions. I how ever can't get any servo's to move. I have read as much as I can find online about the library, I'm still not sure how to setup the program to operate even a single servo. I have used Servo.h in the past successfully, I now am trying to get a handle on ESP32servo. Some assistance please with organizing a servo to sweep, or rotate and stop.
#include <ESP32Servo.h>
//#include "BluetoothSerial.h"
//#include <Esp32WifiManager.h> // https://github.com/tzapu/WiFiManager
#define pitch 5
#define yaw 8
#define roll 10
#define Angle_4 11
#define Left_Aileron 12
#define Right_Aileron 13
#define Rudder 14
#define Elevator 15
#define Trim_Left 16
#define Trim_Right 17
#define SpeedController 18
  //  BluetoothSerial SerialBT;
  //  SerialBT.begin("ESP32test"); //Bluetooth device name
  //  Serial.println("The device started, now you can pair it with bluetooth!");
  Servo Left_Servo_Aileron;
  Servo Right_Servo_Aileron;
  Servo Trim_L;
  Servo Trim_R;
  Servo Elevator_Pos;
  Servo Rudder_Pos;
  Servo MotorSpeedController;
  Left_Servo_Aileron.setPeriodHertz(50);
  Left_Servo_Aileron.attach(Left_Aileron,1000,2500);
//  Servo::setTimerWidth(16);
  Left_Servo_Aileron.setTimerWidth(16);
  Left_Servo_Aileron.write(450);
  Left_Servo_Aileron.Servo::writeMicroseconds (2000);
 // Left_Servo_Aileron.read();                // Gets the last written servo pulse width as an angle between 0 and 180.
  Left_Servo_Aileron.readTimerWidth();      // Gets the PWM timer width (ESP32 ONLY)
Serial.println(Left_Servo_Aileron.readTimerWidth());
// We are using "Left_Aileron" pin 12
  //  Left_Servo_Aileron.write(1450);//
//  Left_Servo_Aileron.setTimerWidth(15);
//  Left_Servo_Aileron.writeMicroseconds (1450);
  //   for (int pos = 0; pos <= 180; pos += 1) {
  //    delay(14);                       // waits 15 ms for the servo to reach the position
  // Time = micros();
  // Time = millis();
  //  if (Time <= 20) {
  //  Serial.println(is_attached[0]);
  //  else {
  //    Serial.println("Done");
How are the servos powered? Post a schematic and photos of your wiring.
Hi groundFungus,
I have already ruled out the wiring. It would appear the servo is faulty. Time to buy some new a ones.
Edit: I have opened the faulty servos and found that the potentiometers post has been cut off and glued into its housing.
