#include <EnableInterrupt.h>
#include <Servo.h>
#include <eRCaGuy_Timer2_Counter.h>
#define SERIAL_SPEED 115200
#define SERIAL_DELAY 4 // If Servos attached, use small value
// ***** Debug Output - If defined, enable Serial Monitor *****
// ***** EXPECT SERVO JITTER IN DEBUG MODE *****
#define DEBUG_SETUP // Must be defined if any of the below are defined
#define DEBUG_RX // Debug Output for Receiver Input
// #define DEBUG_SERVO // Debug Output for Servo Output
// #define DEBUG_MIXING // Debug Output for Signal Processing
// ***** rx INPUT *****
#define RX_TOTAL_CHANNELS 6
#define rxThr 0
#define rxAil 1
#define rxEle 2
#define rxRud 3
#define rxAux1 4
#define rxAux2 5
#define rxThr_PIN 2
#define rxAil_PIN 3
#define rxEle_PIN 4
#define rxRud_PIN 5
#define rxAux1_PIN 6
#define rxAux2_PIN 7
// ***** rx Servo Output *****
#define SERVO_TOTAL_CHANNELS 6
#define dtLowRate 0.25
#define dtHighRate 1.0
#define ltAil 0
#define ltTV 1
#define ltESC 2
#define rtESC 3
#define rtTV 4
#define rtAil 5
#define ltAil_PIN 8
#define ltTV_PIN 9
#define ltESC_PIN 10
#define rtESC_PIN 11
#define rtTV_PIN 12
#define rtAil_PIN 13
uint16_t rxPulse[RX_TOTAL_CHANNELS];
uint64_t rxPulseStart[RX_TOTAL_CHANNELS];
volatile uint16_t rxPulseTemp[RX_TOTAL_CHANNELS];
volatile uint32_t ltAilPulse, ltTVPulse, ltESCPulse, rtESCPulse, rtTVPulse, rtAilPulse;
volatile float DTRate;
Servo ServoArray[SERVO_TOTAL_CHANNELS];
// ***** rx INPUTS *****
void rxReadPulse() {
noInterrupts();
memcpy(rxPulse, (const void *)rxPulseTemp, sizeof(rxPulseTemp));
interrupts();
void calc_input(uint8_t channel, uint8_t input_pin) {
if (digitalRead(input_pin) == HIGH) {
rxPulseStart[channel] = timer2.get_count()/2;
uint16_t rxPulsTotal = (uint16_t)((timer2.get_count()/2) - rxPulseStart[channel]);
rxPulseTemp[channel] = rxPulsTotal;
void calc_Thr() {
calc_input(rxThr, rxThr_PIN);
void calc_Ail() {
calc_input(rxAil, rxAil_PIN);
void calc_Ele() {
calc_input(rxEle, rxEle_PIN);
void calc_Rud() {
calc_input(rxRud, rxRud_PIN);
void calc_Aux1() {
calc_input(rxAux1, rxAux1_PIN);
void calc_Aux2() {
calc_input(rxAux2, rxAux2_PIN);
double reverse(double val) {
return (val - 1500) * -1 + 1500;
double add(double val1, double val2) {
double out = (val1 - 1500 + val2 - 1500) + 1500;
out = (out < 1000) ? 1000 : out;
out = (out > 2000) ? 2000 : out;
return out;
void mixElevon(void) {
ltAilPulse = add(rxPulse[rxAil], rxPulse[rxEle]);
rtAilPulse = add(rxPulse[rxAil], reverse(rxPulse[rxEle]));
void mixThrottle(void) {
float yaw_pct, thr_pct;
double upMod, dwnMod;
uint32_t ltESCTmp, rtESCTmp;
yaw_pct = ((float)rxPulse[rxRud] - 1500) / (float)500; // Value Between -1 and 1: 0 for Center, -1 full left, 1 full right
thr_pct = ((float)rxPulse[rxThr] - 1000) / (float)1000; // Value Between 0 and 1: .5 for Mid Throttle
if (yaw_pct < (float)-1.0) { yaw_pct = (float)-1.0; } // Constrain values between -1.0 and 1.0
else if (yaw_pct > (float)1.0) { yaw_pct = (float)1.0; }
if (thr_pct < (float)0.0) { yaw_pct = (float)0.0; } // Constrain values between 0.0 and 1.0
else if (thr_pct > (float)1.0) { thr_pct = (float)1.0; }
dwnMod = abs(yaw_pct) * (rxPulse[rxThr] - 1000) * DTRate; // Calculate Rudder Pulse Size Constrained by Amount of Throttle
upMod = dwnMod * float(1-thr_pct); // Up Modifier has less of an effect as throttle increases.
#ifdef DEBUG_MIXING
Serial.print("MIXING - rate: "); Serial.print(DTRate);
Serial.print(" yawP: "); Serial.print(yaw_pct);
Serial.print(" thrP: "); Serial.print(thr_pct);
Serial.print(" uMod: "); Serial.print(upMod);
Serial.print(" dMod: "); Serial.println(dwnMod);
#endif
if (yaw_pct < 0) { // Rudder Left
ltESCTmp = reverse(rxPulse[rxThr] - dwnMod);
ltESCPulse = constrain(ltESCTmp, 988, 2012);
rtESCTmp = rxPulse[rxThr] + upMod;
rtESCPulse = constrain(rtESCTmp, 988, 2012);
else { // Rudder Right
ltESCTmp = reverse(rxPulse[rxThr] + upMod);
rtESCTmp = rxPulse[rxThr] - dwnMod;
// SETUP
// General Setup
#ifdef DEBUG_SETUP
Serial.begin(SERIAL_SPEED);
Serial.println(" ");
Serial.println(" Copyright (C) 2017 - Jim Lander (jamieFL)");
Serial.println(" This program comes with ABSOLUTELY NO WARRANTY. It is free software: you can redistribute it and/or modify ");
Serial.println(" it under the terms of the GNU General Public License. For details, see http://www.gnu.org/licenses/");
delay(2000);
#endif
timer2.setup(); //this MUST be done before the other Timer2_Counter functions work; Note: since this messes up PWM outputs on pins 3 & 11, as well as
//interferes with the tone() library (http://arduino.cc/en/reference/tone), you can always revert Timer2 back to normal by calling
//timer2.unsetup()
//rx INPUTS
pinMode(rxThr_PIN, INPUT);
pinMode(rxAil_PIN, INPUT);
pinMode(rxEle_PIN, INPUT);
pinMode(rxRud_PIN, INPUT);
pinMode(rxAux1_PIN, INPUT);
pinMode(rxAux2_PIN, INPUT);
enableInterrupt(rxThr_PIN, calc_Thr, CHANGE);
enableInterrupt(rxAil_PIN, calc_Ail, CHANGE);
enableInterrupt(rxEle_PIN, calc_Ele, CHANGE);
enableInterrupt(rxRud_PIN, calc_Rud, CHANGE);
enableInterrupt(rxAux1_PIN, calc_Aux1, CHANGE);
enableInterrupt(rxAux2_PIN, calc_Aux2, CHANGE);
// Servo OUTPUT
ServoArray[ltAil].attach(ltAil_PIN, 900, 2100); // Left Elevon
ServoArray[ltTV].attach (ltTV_PIN, 900, 2100); // Left Thrust Vector Servo
ServoArray[ltESC].attach(ltESC_PIN, 900, 2100); // Left ESC
ServoArray[rtESC].attach(rtESC_PIN, 900, 2100); // Right ESC
ServoArray[rtTV].attach (rtTV_PIN, 900, 2100); // Right Thrust Vector Servo
ServoArray[rtAil].attach(rtAil_PIN, 900, 2100); // Right Elevon
// LOOP
rxReadPulse(); // get current rx INPUTS
#ifdef DEBUG_RX
Serial.print("RECEIVER - Thr: "); Serial.print(rxPulse[rxThr]); // Pring rx INPUTS
Serial.print(" Ail: "); Serial.print(rxPulse[rxAil]);
Serial.print(" Ele: "); Serial.print(rxPulse[rxEle]);
Serial.print(" Rud: "); Serial.print(rxPulse[rxRud]);
Serial.print(" Aux1: "); Serial.print(rxPulse[rxAux1]);
Serial.print(" Aux2: "); Serial.println(rxPulse[rxAux2]);
#endif
// Perform Elevon, Thust Vectoring, and Differential Thrust Mixing
if (rxPulse[rxAux1] < 1250) { // MODE 1
mixElevon(); // Elevon Mixing: ON
rtTVPulse = 1500; // Thrust Vecoting: OFF
ltTVPulse = 1500;
rtESCPulse = rxPulse[rxThr]; // Differential Thrust: OFF
ltESCPulse = reverse(rxPulse[rxThr]);
else if (rxPulse[rxAux1] > 1750) { // MODE 3
rtTVPulse = rtAilPulse; // Thrust Vectoring: ON
ltTVPulse = ltAilPulse;
DTRate = dtHighRate; // Differential Thrust: ON at HIGHT Rate
mixThrottle();
else { // MODE 2
rtTVPulse = 1500; // Thrust Vectoring: OFF
ltTVPulse = 1500;
DTRate = dtLowRate; // Differential Thrust: ON at LOW Rate
mixThrottle();
ServoArray[ltAil].writeMicroseconds(ltAilPulse);
ServoArray[ltTV].writeMicroseconds(ltTVPulse);
ServoArray[ltESC].writeMicroseconds(ltESCPulse);
ServoArray[rtESC].writeMicroseconds(rtESCPulse);
ServoArray[rtTV].writeMicroseconds(rtTVPulse);
ServoArray[rtAil].writeMicroseconds(rtAilPulse);
#ifdef DEBUG_SERVO
Serial.print("SERVOS - ltAl: "); Serial.print(ltAilPulse); // Print Servo OUTPUTS
Serial.print(" rtAl: "); Serial.print(rtAilPulse);
Serial.print(" ltTV: "); Serial.print(ltTVPulse);
Serial.print(" rtTV: "); Serial.print(rtTVPulse);
Serial.print(" lESC: "); Serial.print(ltESCPulse);
Serial.print(" rESC: "); Serial.println(rtESCPulse);
delay(SERIAL_DELAY);
#endif
