Can I use servo.write() inside an interrupt function callback like in the example below?
#include "Timer.h"
#include <Servo.h>
Servo myservo;
Timer t;
volatile int step = 0;
setup()
t.every(10, rotate);
myservo.attach(9);
step = 0;
loop()
t.update();
rotate()
myservo.write(step);
step++;
I don't see why not, but the 20ms update cycle of a servo is not exactly the sort of territory where an interrupt is necessary or appropriate.
BTW. sp. "void loop () {", "void setup () {" etc
Make sure that the timer and servo libraries use different timers. Such conflicts are common.
I was worried that myservo.write() use some interrupts.
Then what should I do if I want to update it every 20ms, but I don't want to use delays?
Cooperative multitasking, aka " blink without delay"
Study this excellent tutorial: https://www.baldengineer.com/blink-without-delay-explained.html
To answer questions like that (and also learn if there are timer conflicts), examine the library source code: https://github.com/arduino-libraries/Servo/tree/master/src
You can disable timers in conflict in this way:
system
Closed
8
