Hey guys,
I am working on a project with a servo and want to detach it at certain stages in the programm in order to manually move the servo. The detach function works but when I use myservo.attach() in the void loop it wont work.
What am I doing wrong? Does the attach function not work in loop?
How the Hell do we know?
You didn't post any code.
When you do, use code tags.
I am sorry, here is the code. I am using it just for testing right now to figure out why the servo wont work
#include <Servo.h>
#define PIN 10
Adafruit_NeoPixel strip = Adafruit_NeoPixel(8, PIN, NEO_GRB + NEO_KHZ800);
Servo myservo;
int PWI = 2; //POwer Connection Indicator
int PWS = 3; //is Mainboard turned on Indicator
boolean windowsbooted = 0;
int uppos = 30;
int downpos = 0;
boolean servosetback = 0;
myservo.attach(5);
pinMode(PWI, INPUT);
pinMode(PWS, INPUT);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
delay (50);
myservo.write(0);
delay (1000);
myservo.write(uppos);
Serial.println("Servo Uppos");
delay(200);
myservo.detach();
Serial.println("Servo Detached");
myservo.write(downpos);
delay(2000);
myservo.attach(5);
Serial.println("Servo reatached");
delay(2000);
Serial.println("Servo Downpos");
delay(2000);
// if(digitalRead(PWS) == HIGH && windowsbooted == 0){
// //myservo.write(uppos);
// colorWipe(strip.Color(60, 30, 0), 50);
// myservo.write(uppos);
// servosetback = 0;
// colorWipe(strip.Color(0,0 , 30), 50);
// windowsbooted = 1;
// if(digitalRead(PWS) == HIGH && windowsbooted == 1){
// if(digitalRead(PWS) == LOW && servosetback == 0){
// windowsbooted = 0;
// myservo.write(0);
// colorWipe(strip.Color(0,0 , 0),10 );
// servosetback = 1;
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
So, what happens?
What doesn't happen that you expect to happen?
Like I said the attach function for some reason wont work.
I am calling it in void loop after I detached the servo. I figured after calling attach I would be able to move the servo again but that doesnt work. The serial communication is just for debugging, so I see where I am at in the programm.
How do you know the attach() doesn't work? It doesn't do anything of itself.
What are the symptoms?
What actually happens?
And what should happen?
...R
After I call attach I am moving the servo to its zero position. However that doesn't work.
It just stays there and does nothing.
You only allow 1/5th of a second for the servo to reach "uppos" - is that enough?
Yes that is enough. I am Using a retrct servo for certain reasons and it only allows for either going to 0° or 180° nothing inbetween.
So i am only letting it move 1/5th of a second in order to move it around 45 degrees. That works pretty well so far.
I modified your code a little so it is (hopefully) clearer what is happening.
I think your "problem" is that the write(downpos) that is sent while the servo is detached is acted upon immediately it is reattached.
#include <Servo.h>
#define PIN 10
Servo myservo;
int uppos = 120;
int downpos = 20;
myservo.attach(5);
delay (50);
myservo.write(0);
delay (1000);
delay(2000);
myservo.detach();
Serial.println("Try Downpos");
delay(2000);
myservo.attach(5);
Serial.println("Servo reattached");
delay(2000);
delay(2000);
delay(2000);
...R
I don't think servo position can be controlled reliably by limiting execution time.
I think you need to explore other ways to get 45 degrees
Some servo test code that includes the attach/detach function.
// zoomkat 12-25-13 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// Send an a to attach servo or d to detach servo
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
String readString; //String captured from serial port
Servo myservo; // create servo object to control a servo
int n; //value to write to servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7, 500, 2500); //the pin for the servo control, and range if desired
Serial.println("servo all-in-one test code 12-25-13"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
// attach or detach servo if desired
if (readString == "d") {
myservo.detach(); //detach servo
Serial.println("servo detached");
goto bailout; //jump over writing to servo
if (readString == "a") {
myservo.attach(7); //reattach servo to pin 7
Serial.println("servo attached");
goto bailout;
n = readString.toInt(); //convert readString into a number
// auto select appropriate value
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
bailout: //reenter code loop
Serial.print("Last servo command position: ");
Serial.println(myservo.read());
readString=""; //empty for next input
