Hello to anybody who sees this. I am currently building a SCARA arm and have almost completed the build. I have found the designs and work on howtomechatronics.com and thought they were great so I built it. Everything works except the servo motor powering the gripper. The issue is that when the Arduino Uno is connected to power, the gripper just constantly turns and doesn't stop ever. I have no clue as to how to fix it and I will link the code below.
Arduino based SCARA Robot
by Dejan, www.HowToMechatronics.com
AccelStepper: http://www.airspayce.com/mikem/arduino/AccelStepper/index.html
#include <AccelStepper.h>
#include <Servo.h>
#include <math.h>
#define limitSwitch1 11
#define limitSwitch2 10
#define limitSwitch3 9
#define limitSwitch4 A3
// Define the stepper motors and the pins the will use
AccelStepper stepper1(1, 2, 5); // (Type:driver, STEP, DIR)
AccelStepper stepper2(1, 3, 6);
AccelStepper stepper3(1, 4, 7);
AccelStepper stepper4(1, 12, 13);
Servo grippAerServo; // create servo object to control a servo
double x = 10.0;
double y = 10.0;
double L1 = 228; // L1 = 228mm
double L2 = 136.5; // L2 = 136.5mm
double theta1, theta2, phi, z;
int stepper1Position, stepper2Position, stepper3Position, stepper4Position;
const float theta1AngleToSteps = 44.444444;
const float theta2AngleToSteps = 35.555555;
const float phiAngleToSteps = 10;
const float zDistanceToSteps = 100;
byte inputValue[5];
int k = 0;
String content = "";
int data[10];
int theta1Array[100];
int theta2Array[100];
int phiArray[100];
int zArray[100];
int gripperArray[100];
int positionsCounter = 0;
pinMode(limitSwitch1, INPUT_PULLUP);
pinMode(limitSwitch2, INPUT_PULLUP);
pinMode(limitSwitch3, INPUT_PULLUP);
pinMode(limitSwitch4, INPUT_PULLUP);
// Stepper motors max speed
stepper1.setMaxSpeed(4000);
stepper1.setAcceleration(2000);
stepper2.setMaxSpeed(4000);
stepper2.setAcceleration(2000);
stepper3.setMaxSpeed(4000);
stepper3.setAcceleration(2000);
stepper4.setMaxSpeed(4000);
stepper4.setAcceleration(2000);
gripperServo.attach(A0, 600, 2500);
// initial servo value - open gripper
data[6] = 180;
gripperServo.write(data[6]);
data[5] = 100;
homing();
if (Serial.available()) {
content = Serial.readString(); // Read the incomding data from Processing
// Extract the data from the string and put into separate integer variables (data[] array)
for (int i = 0; i < 10; i++) {
int index = content.indexOf(","); // locate the first ","
data[i] = atol(content.substring(0, index).c_str()); //Extract the number from start to the ","
content = content.substring(index + 1); //Remove the number from the string
data[0] - SAVE button status
data[1] - RUN button status
data[2] - Joint 1 angle
data[3] - Joint 2 angle
data[4] - Joint 3 angle
data[5] - Z position
data[6] - Gripper value
data[7] - Speed value
data[8] - Acceleration value
// If SAVE button is pressed, store the data into the appropriate arrays
if (data[0] == 1) {
theta1Array[positionsCounter] = data[2] * theta1AngleToSteps; //store the values in steps = angles * angleToSteps variable
theta2Array[positionsCounter] = data[3] * theta2AngleToSteps;
phiArray[positionsCounter] = data[4] * phiAngleToSteps;
zArray[positionsCounter] = data[5] * zDistanceToSteps;
gripperArray[positionsCounter] = data[6];
positionsCounter++;
// clear data
if (data[0] == 2) {
// Clear the array data to 0
memset(theta1Array, 0, sizeof(theta1Array));
memset(theta2Array, 0, sizeof(theta2Array));
memset(phiArray, 0, sizeof(phiArray));
memset(zArray, 0, sizeof(zArray));
memset(gripperArray, 0, sizeof(gripperArray));
// If RUN button is pressed
while (data[1] == 1) {
stepper1.setSpeed(data[7]);
stepper2.setSpeed(data[7]);
stepper3.setSpeed(data[7]);
stepper4.setSpeed(data[7]);
stepper1.setAcceleration(data[8]);
stepper2.setAcceleration(data[8]);
stepper3.setAcceleration(data[8]);
stepper4.setAcceleration(data[8]);
// execute the stored steps
for (int i = 0; i <= positionsCounter - 1; i++) {
if (data[1] == 0) {
stepper1.moveTo(theta1Array[i]);
stepper2.moveTo(theta2Array[i]);
stepper3.moveTo(phiArray[i]);
stepper4.moveTo(zArray[i]);
while (stepper1.currentPosition() != theta1Array[i] || stepper2.currentPosition() != theta2Array[i] || stepper3.currentPosition() != phiArray[i] || stepper4.currentPosition() != zArray[i]) {
stepper1.run();
stepper2.run();
stepper3.run();
stepper4.run();
if (i == 0) {
gripperServo.write(gripperArray[i]);
else if (gripperArray[i] != gripperArray[i - 1]) {
delay(800); // wait 0.8s for the servo to grab or drop - the servo is slow
//check for change in speed and acceleration or program stop
if (data[1] == 0) {
// change speed and acceleration while running the program
// execute the stored steps in reverse
for (int i = positionsCounter - 2; i >= 0; i--) {
if (data[1] == 0) {
stepper1.run();
stepper2.run();
stepper3.run();
stepper4.run();
if (data[1] == 0) {
stepper1Position = data[2] * theta1AngleToSteps;
stepper2Position = data[3] * theta2AngleToSteps;
stepper3Position = data[4] * phiAngleToSteps;
stepper4Position = data[5] * zDistanceToSteps;
stepper1.moveTo(stepper1Position);
stepper2.moveTo(stepper2Position);
stepper3.moveTo(stepper3Position);
stepper4.moveTo(stepper4Position);
while (stepper1.currentPosition() != stepper1Position || stepper2.currentPosition() != stepper2Position || stepper3.currentPosition() != stepper3Position || stepper4.currentPosition() != stepper4Position) {
stepper1.run();
stepper2.run();
stepper3.run();
stepper4.run();
delay(100);
delay(300);
void serialFlush() {
while (Serial.available() > 0) { //while there are characters in the serial buffer, because Serial.available is >0
Serial.read(); // get one character
void homing() {
// Homing Stepper4
while (digitalRead(limitSwitch4) != 1) {
stepper4.setSpeed(1500);
stepper4.runSpeed();
stepper4.setCurrentPosition(17000); // When limit switch pressed set position to 0 steps
delay(20);
stepper4.moveTo(10000);
while (stepper4.currentPosition() != 10000) {
stepper4.run();
// Homing Stepper3
while (digitalRead(limitSwitch3) != 1) {
stepper3.setSpeed(-1100);
stepper3.runSpeed();
stepper3.setCurrentPosition(-1662); // When limit switch pressed set position to 0 steps
delay(20);
stepper3.moveTo(0);
while (stepper3.currentPosition() != 0) {
stepper3.run();
// Homing Stepper2
while (digitalRead(limitSwitch2) != 1) {
stepper2.setSpeed(-1300);
stepper2.runSpeed();
stepper2.setCurrentPosition(-5420); // When limit switch pressed set position to -5440 steps
delay(20);
stepper2.moveTo(0);
while (stepper2.currentPosition() != 0) {
stepper2.run();
// Homing Stepper1
while (digitalRead(limitSwitch1) != 1) {
stepper1.setSpeed(-1200);
stepper1.runSpeed();
stepper1.setCurrentPosition(-3955); // When limit switch pressed set position to 0 steps
delay(20);
stepper1.moveTo(0);
while (stepper1.currentPosition() != 0) {
stepper1.run();
