Hi everyone,
I would like to thank you for spending your precious time going through my the problem that i am currently facing. I'm currently doing a project, using arduino UNO, moxa (Relay Box), and self created sencha touch 2 application to control the device. this is to simulate, using application to control home devices like door, window, tv, lights and beds. The following points are the materials used and the problem I faced:
Materials used:
1 X arduino UNO
2 X HS-65HB HITech servo Motor
1 X HS-81HB HITech Servo Motor
1 X Moxa ioLogik E1214 Relay
Problems:
- Servo Motor Keep vibrating
- When Light being switched on, it it also activate the window ( servo motor HS-65-HB )
Questions:
- how to prevent the motor from vibrating?
- how to write the code, so that the motor will stay at the angle that i wanted
Thank you
Sorry for my bad English
