//YWROBOT
//Comible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#define SD_ChipSelectPin 4
#include <TMRpcm.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo
TMRpcm tmrpcm;
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 20 chars and 4 line display
int L1 = 2;
int L2 = 3;
int L3 = 5;
int L4 = 6;
int L5 = 8; //5 LED pin
int buttonPin = 7; //the number of the pushbutton pin
int de=5000; // delay time
int p=0; // variable for patten
int buttonState = 0; //variable for reading the pushbutton status
unsigned long servoMillis = 0;
unsigned long servointerval = de;
lcd.init(); // initialize the lcd
lcd.init(); // Print a message to the LCD.
pinMode(L1, OUTPUT);
pinMode(L2, OUTPUT);
pinMode(L3, OUTPUT);
pinMode(L4, OUTPUT);
pinMode(L5, OUTPUT);
pinMode(buttonPin, INPUT);
tmrpcm.speakerPin = 9;
if (!SD.begin(SD_ChipSelectPin)){
Serial.println("SD fail");
return;
myservo.attach(10); // attaches the servo on pin 10 to the servo object
tmrpcm.setVolume(5);
tmrpcm.play("0.wav");
lcd.backlight();
lcd.setCursor(6,0);
lcd.print("HELLO");
lcd.setCursor(0,1);
lcd.print("TALKING DISCHARGEROD");
lcd.setCursor(4,2);
lcd.print("WELCOMES YOU");
lcd.setCursor(0,3);
lcd.print("PLEASE FOLLOW INST..");
delay(8000);
lcd.clear();
tmrpcm.play("1.wav");
lcd.setCursor(1,1);
lcd.print("WEAR ELECTRICAL PPE");
delay(de);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
p++;
delay(2000);
if(p == 1)
if(millis() - servoMillis > servointerval) {
servoMillis = millis();
digitalWrite(L1,1);
digitalWrite(L2,0);
digitalWrite(L3,0);
digitalWrite(L4,0);
digitalWrite(L5,0); //1
lcd.clear();
lcd.setCursor(2,0);
lcd.print("CHECK NO VOLTAGE");
lcd.setCursor(7,1);
lcd.print("USING");
lcd.setCursor(2,2);
lcd.print("VOLTAGE DETECTOR");
tmrpcm.play("2.wav");
if(p == 2)
digitalWrite(L1,1);
digitalWrite(L2,1);
digitalWrite(L3,0);
digitalWrite(L4,0);
digitalWrite(L5,0); //2
tmrpcm.play("3.wav");
lcd.clear();
lcd.setCursor(3,1);
lcd.print("CONNECT CLAMP");
lcd.setCursor(2,2);
lcd.print("WITH EARTH STRIP");
if(p == 3)
digitalWrite(L1,1);
digitalWrite(L2,1);
digitalWrite(L3,1);
digitalWrite(L4,0);
digitalWrite(L5,0); //3
tmrpcm.play("4.wav");
lcd.clear();
lcd.setCursor(2,0);
lcd.print("CHECK CONTINUITY");
lcd.setCursor(6,1);
lcd.print("BETWEEN");
lcd.setCursor(2,2);
lcd.print("CLAMP AND GROUND");
if(p == 4)
digitalWrite(L1,1);
digitalWrite(L2,1);
digitalWrite(L3,1);
digitalWrite(L4,1);
digitalWrite(L5,0); //4
tmrpcm.play( "5.wav");
lcd.clear();
lcd.setCursor(1,1);
lcd.print("WE ARE GOOD TO GO");
lcd.setCursor(1,2);
lcd.print("FOR SAFE DISCHARGE");
for (pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
delay(de);
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(50); // waits 15ms for the servo to reach the position
if(p == 5)
digitalWrite(L1,1);
digitalWrite(L2,1);
digitalWrite(L3,1);
digitalWrite(L4,1);
digitalWrite(L5,1);
for (pos = 90; pos >= 0; pos += 1) { // goes from 0 degrees to 180 degrees
delay(de);
