Servo Not Moving
I have made a project that checks the code entered by user , if it is correct it displays "correct" else "try again". When the code is entered correct I want the servo to move 90 degrees , which it is not moving. Any idea what did I do wrong.
COMPONENTS: Servo, Push buttons. Arduino Uno, Oled (128 by 64) .
CODE:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Servo.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define BUTTON_1 2
#define BUTTON_2 3
#define BUTTON_3 4
#define SERVO_PIN 9
const int sequence[] = {1, 2, 3}; // Desired sequence of button presses
int userInput[3]; // Array to store user input
int inputIndex = 0; // Index for user input
unsigned long lastButtonPressTime = 0; // Timestamp of last button press
unsigned long debounceDelay = 50; // Debounce delay time in milliseconds
unsigned long buttonDelay = 1000; // Delay after button press in milliseconds
Servo servo;
  pinMode(BUTTON_1, INPUT_PULLUP);
  pinMode(BUTTON_2, INPUT_PULLUP);
  pinMode(BUTTON_3, INPUT_PULLUP);
  Wire.begin();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Address 0x3C for 128x64
  servo.attach(SERVO_PIN);
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(0, 0);
  display.println("Push buttons:");
  display.println("1 - 2 - 3");
  display.display();
  int buttonPressed = checkButtons();
  if (buttonPressed != 0 && millis() - lastButtonPressTime > buttonDelay) {
    userInput[inputIndex] = buttonPressed;
    inputIndex++;
    displayInput();
    lastButtonPressTime = millis();
  if (inputIndex == 3) {
    checkSequence();
int checkButtons() {
  if (digitalRead(BUTTON_1) == LOW) {
    delay(debounceDelay); // Debounce delay
      return 1;
  if (digitalRead(BUTTON_2) == LOW) {
      return 2;
  if (digitalRead(BUTTON_3) == LOW) {
      return 3;
  return 0;
void displayInput() {
  for (int i = 0; i < inputIndex; i++) {
    display.print(userInput[i]);
    display.print(" ");
  display.display();
void checkSequence() {
  bool correct = true;
  for (int i = 0; i < 3; i++) {
    if (userInput[i] != sequence[i]) {
      correct = false;
  if (correct) {
    display.println("Code is correct!");
    servo.write(90); // Move servo to 90 degrees
    display.println("Try again!");
  display.display();
  delay(2000); // Delay to allow user to see the result
  resetInput();
void resetInput() {
  inputIndex = 0;
    userInput[i] = 0;
Have you tested the circuit with the "Sweep" example sketch from the help menu?
I tested, it works
Default position for a servo is 90 and you never move it anywhere else. Try sending it to 45 in setup and see if it moves then and when the sequence is correct.
