Moving a servo 90 degrees and then back to its original position with a push of a button
Hi, I am pretty new to coding and Arduino I need help to make it in real life. I found this code. So if anyone can help it would be a real life saver.
Thank you
#include <Servo.h>
Servo myServo;
const int switchPin = 8;
int buttonState = 0;
int lastButtonState = 0;
int buttonPushCounter = 0;
  myServo.attach(4);
  myServo.write(0);
void push(){
  myServo.write(90);
delay(250);
myServo.write(0);
  buttonState = digitalRead(switchPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
   // turns on the LED every four button pushes by checking the modulo of the
  // button push counter. the modulo function gives you the remainder of the
  // division of two numbers:
  if (buttonPushCounter % 2 == 0) {
    push();
What is the problem? Help with what?
Where did you find that code?
Which Arduino?
Show your wiring.
It is usually a bad idea to power the servo from the Arduino 5V or USB power. Use an external supply capable of supplying the servo stall current. Connect the grounds.
I found the code here:
How to make a servo motor rotate 90 degrees then back to its original position
Arduino Uno
Problem is how to make the code better and help with the wiring.
Thanks but where do I add the button and what voltage power supply?
buttons are typically connected between the pin and ground, the pin configured as INPUT_PULLUP to use the internal pullup resistor which pulls the pin HIGH and when pressed, the button pulls the pin LOW.
look this over (a bit simpler)
# include <Servo.h>
Servo myServo;
const int SwitchPin = 8;
byte butLst;
int  butCnt;
void setup ()
    Serial.begin (9600);
    pinMode (SwitchPin, INPUT_PULLUP);
    butLst = digitalRead (SwitchPin);
    myServo.attach (4);
void loop ()
    byte but = digitalRead (SwitchPin);
    if (butLst != but)  {   // change
        butLst = but;
        delay (20);         // debounce
        if (LOW == but)  {  // press
            butCnt++;
            Serial.println (butCnt);
            if (butCnt % 2)
                myServo.write (90);     // odd
                myServo.write (0);      // even
The cap on the switch is optional. It is there to help with switch debounce.
Consult the data sheet or manual for the servo. It is usually 4.8-6V but check the datasheet.
I tried this code but I have to press the button once to go to 90 degrees and then again to go back to 0. I want all that to be in one press, not two. I also want to make the servo move faster. If you could help that would be great.
Thanks
What is supposed to make it go back to zero? Un-pressing the button? Waiting for a certain tie after you pushed the button? Waiting for a certain time after you released the button?
Hello rexyspy
Consider:
//includes
#include <Servo.h>
Servo myServo;
//variables
constexpr uint8_t ServoPin {4};
constexpr uint8_t ButtonPin {8};
  pinMode (ButtonPin, INPUT_PULLUP);
  myServo.attach(ServoPin);
  myServo.write(0);
  myServo.write(digitalRead(ButtonPin)?90:0);
HTH
Thank you so much paulpaulson this was exactly what I wanted.
Thank you
If anyone else wants to make this here is the wiring
See post #2. It is a mistake to power the servo from the Uno 5V or USB.
