Servo-Problems with an AtMega328p
I am having problems with controlling a servo with an AtMega328p, first it behaves weird then it stops working completely(until i disconnect it and then reconnect it to the power source). I am powering it with a 16 mhz crystal and 2 22pf caps and i am using the standard Servo.h library. It works like it should if i use a full-size-arduino but it is to big for this project.
Any help or tips would be appreciated!
POWER problem: You must supply the servo with 5 or 6 V at (probably more than 1 amp - WHAT servo do,you have??)
Best to have separate 5V supply to servo, grounds connected together...
Thanks for the awnser but don't think that the amperage is a problem!
Reason 1:It does work with a complete arduino uno powered through usb
Reason 2:I tried using a power supply that can deliver up to 4 amps at 5 volts DC but it still didnt work
I rather think it has something to do with a missing component i need to control a servo correctly.
btw i am using a 'reely s-0403'.
How have you built your arduino version? Where is "Ground"?? Where is servo "ground" connected? (Best would be - terminal of your power supply.
Sounds like electromagnetic interference, ground bounce etc..
It switches between random positions as soon as you apply any force ( and it should correct it's self).
then it just stops working completely until i repower it!
Circuit:
Wow, that is a difficult image to try to decipher. I see why so many here hate fritzing.
A pencil and paper will let you identify which pins are being used.
I found out that it most definitely does not have anything to do with interfeirance because i tried a using just a powering circuit for the 328p (and of course attaching the servo like usual) but it still didn't work!
