Hi I am building an RC boat that I want 2 servos to sweep (search lights) 1 from 0 to 180 and 1 from 180 to 0 I have no idea of programming and only come across this by surfing for a solution for my model I can add another servo to the code no problem done and tested. how do i code for the above.
as you can see below I have added the other servo and both sweep the same way, any help would be greatly appreciated.
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
Servo myservo2;
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo2.attach(10);
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
myservo2.write(pos);
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
[code]
