Hello! I’ve got an Arduino Mega controlling a coffee roaster via relays, PWM and one servo.
The Arduino is driven by a Python WebSocket hub that sends commands over serial (115200 baud). This is a project for which i surely am under qualified so there is a lot of vibe coding included.
Everything works fine at first, but after some minutes of use, my servo “OPEN/CLOSE” commands become weird:
sometimes the servo starts moving with a big delay
sometimes it moves only =s instead of 2-3s and then stops
sometimes it doesn’t move at all, or only twitches
If I disconnect the Python hub and talk to the Arduino directly through the Serial Monitor, the servo SEEMS to behave perfectly fine and always runs for the correct duration. So this feels like a timing/serial issue, however i am still considering a hardware issue perhaps something with the relays and the common GND. not sure though I'd rly appreciate your thoughts. (I'm only saying that because i noticed something that only happened ONCE. when i was switching between 1, 2 and 3 resistors, the servo would move for like 0.2s. idk how that happened.
below i will include parts of my code but if you think its needed i can provide the whole files.
arduino side:
// Servo timing state
bool servoMoving = false;
unsigned long servoMoveStart = 0;
int servoMoveDuration = 0;
const int SERVO_OPEN_SPEED = 2000;
const int SERVO_CLOSE_SPEED = 1000;
int SERVO_OPEN_TIME_MS = 1900; // how long to OPEN
int SERVO_CLOSE_TIME_MS = 2600; // how long to CLOSE
// 1) Serial command handling
if (Serial.available()) {
String line = Serial.readStringUntil('\n');
line.trim();
if (line.length() > 0) processCommand(line);
// ... relay pulses, watchdog, temp stream ...
// Timed servo auto-stop
if (servoMoving) {
unsigned long elapsed = millis() - servoMoveStart;
// tolerate some delay
if (elapsed >= servoMoveDuration || elapsed > servoMoveDuration + 200) {
drumServo.writeMicroseconds(1500); // stop
Serial.println("SERVO AUTO-STOP");
Command handler:
if (key == "SERVO") {
// SERVO OPEN (actually runs CLOSE direction)
if (arg == "OPEN") {
servoMoving = true;
servoMoveStart = millis();
servoMoveDuration = SERVO_CLOSE_TIME_MS;
drumServo.writeMicroseconds(SERVO_CLOSE_SPEED);
lastServoOpen = true;
Serial.println("SERVO OPEN started");
return;
// SERVO CLOSE (actually runs OPEN direction)
else if (arg == "CLOSE") {
servoMoving = true;
servoMoveDuration = SERVO_OPEN_TIME_MS;
drumServo.writeMicroseconds(SERVO_OPEN_SPEED);
lastServoOpen = false;
Serial.println("SERVO CLOSE started");
return;
else if (arg == "STOP") {
Serial.println("SERVO STOPPED manually");
return;
else {
Serial.println("ERR");
return;
python side:
async def apply_command(action, value=None):
# sanitize...
line = f"{action}" if value is None else f"{action} {value}"
await arduino.send_raw(line) # send command
# optimistic UI update here
await arduino.send_raw("ARDUINO_STATUS") # <-- always right after
# broadcast cached state to all UIs
Accepts commands from a web UI, sends them to Arduino over serial (send_raw("...")), also sends ARDUINO_STATUS after each command to resync state, sends a HEARTBEAT every 1s.
You guys think its mainly timing issue or hardware?
