Hi guys , im new on Arduino programming . im so confuse on how to use millis on servo motor. i have a program here that need millis rather than delay because its affecting my countdown timer, i want my to program synchronous (Servo together with coundown time). can somebody help me out ? thank you so much in advance.
PS. i put some part of the code.
P.S im using Arduino Mega 2560.
//Servo Motors
int pos = 0;
int count = 0;
int top = 0;
int ServoPin1 = 11;
int ServoPin2 = 12;
int out = 2;
//Timer Count
int a, b, c = 0; // ones sec, tens sec, minute
//Button
int setBtn = 53;
int redBtn = 51;
int startBtn = 49;
int previouslyPressed1, previouslyPressed2, previousStart = 0;
//Others
int x = -1;
int AA = 0;
#include <Wire.h>
#include <Servo.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
Servo Servo1;
Servo Servo2;
pinMode(setBtn, INPUT);
pinMode(redBtn, INPUT);
pinMode(startBtn, INPUT);
Servo1.attach(ServoPin1); // Make servo go to 90 degrees
Servo1.write(90);
Servo2.attach(ServoPin2); // Make servo go to 0 degrees
Servo2.write(0);
lcd.clear();
lcd.begin(16, 2);
lcd.setCursor(1, 0);
lcd.print("_*!WELCOME!*_");
delay(2000);
lcd.clear();
while (x == -1)
a = 0;
b = 0;
c = 0;
lcd.setCursor(0, 0);
lcd.print ("Auto ?");
delay(100);
lcd.setCursor(0, 1);
lcd.print ("Manual ?");
delay(100);
if (digitalRead(startBtn) == HIGH) {
lcd.clear();
lcd.print("Auto Selected");
lcd.clear();
x = 0;
else if (digitalRead(setBtn) == HIGH)
lcd.clear();
lcd.print("Manual Selected");
lcd.clear();
x = 1;
while (x == 1)
while (AA == 0)
lcd.setCursor(4, 0);
lcd.print("SET TIME");
delay(1500);
AA = 1;
lcd.clear();
lcd.setCursor(2, 0);
lcd.print("SETTING TIME");
if ((digitalRead(setBtn) == HIGH) && (previouslyPressed1 == 0))
c = c + 5;
previouslyPressed1 = 1;
delay(50);
if ((digitalRead(setBtn) == LOW) && (previouslyPressed1 == 1))
previouslyPressed1 = 0;
delay(50);
if ((digitalRead(redBtn) == HIGH) && (previouslyPressed2 == 0))
c = c - 5;
previouslyPressed2 = 1;
delay(50);
if ((digitalRead(redBtn) == LOW) && (previouslyPressed2 == 1))
previouslyPressed2 = 0;
delay(50);
x = 2;
if (c < 0)
c = 0;
if (c < 10)
lcd.setCursor(5, 1);
lcd.print("0");
lcd.setCursor(6, 1);
lcd.print(c);
lcd.setCursor(7, 1);
lcd.print(":");
lcd.setCursor(8, 1);
lcd.print(b);
lcd.setCursor(9, 1);
lcd.print(a);
lcd.print(c);
lcd.print(":");
lcd.print(b);
lcd.print(a);
while (x == 2)
void startServo();
void timer();
timer();
digitalWrite (out , HIGH);
lcd.write("REMAINING TIME");
if ((a == 0) && (b == 0) && (c == 0))
digitalWrite (out , LOW);
lcd.clear();
lcd.setCursor(3, 0);
lcd.print("TIME's UP!");
x = -1;
AA = 0;
delay(3000);
lcd.clear();
if (digitalRead(setBtn) == HIGH) // PAUSE
x = 0;
if (digitalRead(redBtn) == HIGH) // RESET
a = 0;
b = 0;
c = 0;
lcd.clear();
delay(1500);
x = -1;
AA = 0;
if (digitalRead(startBtn) == HIGH) // PLAY
x = 2;
a = 0;
b = 0;
c = 0;
lcd.clear();
delay(1500);
x = -1;
AA = 0;
void startServo()
for ( count = 0; count <= 4; count++)
for (pos = 40; pos <= 140; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
Servo1.write(pos); // tell servo to go to position in variable 'pos'
delay(5); // waits 15ms for the servo to reach the position
for (pos = 140; pos >= 40; pos -= 1) { // goes from 180 degrees to 0 degrees
Serial.println(count);
if (count == 4)
for (pos = 40; pos <= 90; pos += 1) {
Servo1.write(pos);
delay(5);
top = 1;
if (top == 1)
Servo2.write(pos);
delay(5);
Servo2.write(pos);
delay(5);
if (count == 4)
Servo2.write(pos);
delay(5);
void timer()
if ((a == 0) && (b == 0) && (AA == 1))
lcd.print("0");
lcd.print("0");
c--;
b = 5;
a = 9;
if (c < 0)
c = 0;
if (a < 0)
a = 9;
b--;
if (c < 10)
lcd.print("0");
lcd.print(c);
lcd.print(":");
lcd.print(b);
lcd.print(a);
a--;
lcd.print(c);
lcd.print(":");
lcd.print(b);
lcd.print(a);
a--;
manual.ino (5.91 KB)
