Hello everyone,
I premise that I am not very experienced with Arduino, although I have already done a few projects.
Here is the current project:
I would like to make a timer that is controlled by encoder (HW-040). By turning clockwise, seconds and minutes will go up; counterclockwise, they will go down. Instead, pressing the middle button will start the countdown. During this time, a servo motor (SG90) will have to execute this code
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
When the timer is finished, the stepper will stop and the buzzer will sound.
Here are the connections:
Buzzer 5
Servo (SG90) 7
Encoder HW-40 ( CLK 2; DT 4; SW 3)
Start button 6
Below is the code realized for now:
FILM ROLLER V 1.0
#include <EEPROM.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define encoder0PinA 2
#define encoder0PinB 4
#define pushButton 3
#define pushButtonSTART 6
volatile int encoder0Pos = 4;
volatile boolean PastB = 0;
volatile boolean update = false;
int minuti = 5;
int secondi = 6;
int contatoreFineTempo;
int lastButtonState = 0;
int lastMSB = 0;
int lastLSB = 0;
int lastEncoded = 0;
long encoderValue = 0;
long encoderValue2 = 0;
long encoderValue3 = 0;
long lastencoderValue = 0;
long lastencoderValue2 = 0;
long lastencoderValue3 = 0;
int timeSEC = 0;
int step_funzione = 0;
int buzzer = 5; // Pulsante Buzzer
lcd.init();
lcd.backlight();
pinMode(pushButton, INPUT);
pinMode(pushButtonSTART, INPUT);
pinMode(encoder0PinA, INPUT);
pinMode(encoder0PinB, INPUT);
digitalWrite(encoder0PinB, HIGH);
digitalWrite(encoder0PinA, HIGH);
pinMode(pushButton, INPUT_PULLUP);
pinMode(pushButtonSTART, INPUT_PULLUP);
pinMode(buzzer, OUTPUT); // Inizializza il buzzer
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("FILM ROLLER V 1.0");
lcd.setCursor(0, 1);
lcd.print("TEMP: ");
delay(2000);
lcd.clear();
if (update) {
update = false;
PastB ? encoder0Pos++ : encoder0Pos--;
minuti = lastencoderValue2;
secondi = lastencoderValue3;
switch (step_funzione) {
case 0: // STATO INIZIALE
INIZIO();
case 1: // VAI ALLA FUNZIONE: EDIT TEMPO
EDIT_TEMPO();
case 2: // VAI ALLA FUNZIONE: CONTO ALLA ROVESCIA
COUNT_DOWN();
case 3: // VAI ALLA FUNZIONE: TEMPO SCADUTO
TEMPO_SCADUTO();
void INIZIO() {
lcd.print(" PREMI START ");
lcd.setCursor(4, 1);
if (minuti < 10) lcd.print("0"); // SE I MINUTI SONO MENO DI 10, SCRIVI LO ZERO A SINISTRA.
lcd.print(minuti); // STAMPA I MINUTI
lcd.print(":"); // STAMPA I DUE PUNTI
if (secondi < 10) lcd.print("0"); // SE I SECONDI SONO MENO DI 10, SCRIVI LO ZERO A SINISTRA.
lcd.print(secondi); // STAMPA I SECONDI
int buttonState = digitalRead(pushButton); //// PER ACCEDERE AL MENU EDITOR CON IL MANTENIMENTO DEL PULSANTE ENCODER
if (buttonState == LOW) {
delay (1000);
Serial.println(timeSEC);
timeSEC++;
else {
timeSEC = 0; // AZZERAMENTO VARIABILE SEI SECONDI
delay(100);
if (timeSEC >= 2) { // VAI A EDITOR
lcd.clear();
timeSEC = 0;
step_funzione = 1;
int pushButtonSTARTstate = digitalRead(pushButtonSTART);
if (pushButtonSTARTstate == LOW) {
lcd.clear();
lcd.print("Partenza tempo");
lcd.clear();
timeSEC = 0;
step_funzione = 2;
void EDIT_TEMPO() {
lcd.print("h");
lcd.setCursor(1, 1);
lcd.print(minuti);
lcd.print(":");
lcd.print(secondi);
if (buttonState != lastButtonState)
lcd.clear();
delay(100);
lastButtonState = buttonState;
lcd.clear();
lcd.clear();
timeSEC = 0;
step_funzione = 2;
void COUNT_DOWN() {
while (secondi > 0) {
timeSEC++;
if (timeSEC >= 3) {
lcd.clear();
lcd.print(" reset forzato ");
lcd.print("xxxxxxxxxxxxxxxx");
delay(2000);
lcd.clear();
timeSEC = 0;
step_funzione = 0;
lcd.print(" Tempo residuo: ");
delay (1000); // DELAY PER CONTARE STEP DI UN SECONDO...NON TOCCARE
secondi--;
lcd.print(minuti);
lcd.print(":");
lcd.print(secondi);
if (secondi == 0) {
step_funzione = 3; // VAI AL' ULTIMO STADIO...TEMPO CHE RAGGIUNGE LO ZERO
void TEMPO_SCADUTO() {
lcd.clear();
lcd.print(" ripristino ");
lcd.clear();
timeSEC = 0;
step_funzione = 0;
lcd.print(" Fine tempo ");
lcd.print("Start=Ripristina");
lcd.clear();
// Attiva il buzzer quando il tempo รจ scaduto
digitalWrite(buzzer, HIGH);
if (contatoreFineTempo >= 10) {
contatoreFineTempo = 0;
timeSEC = 0;
step_funzione = 0;
void doEncoderB() {
PastB = (boolean)digitalRead(encoder0PinA);
update = true;
encoderValue2 = encoder0Pos;
encoderValue3 = encoder0Pos;
At the moment the code doesn't work at all, as soon as I connect arduino, the buzzer starts immediately and it doesn't allow me to set the timer.
I am asking for your help to fix the countdown part with the encoder, once that is done I can enter the code that manages the motor and also the buzzer code
