Servomotor Project 5 (edited)
Hello,
I want to modify project 5 (ServoMoodindicator) so that servomotor goes back to his starting angle after adjusting the potmeter, see code (??).
I hope someone can help me out.
Greetings,
Kaz
Arduino Starter Kit example
Project 5 - Servo Mood Indicator
This sketch is written to accompany Project 5 in the Arduino Starter Kit
Parts required:
  • servo motor
  • 10 kilohm potentiometer
  • two 100 uF electrolytic capacitors
created 13 Sep 2012
by Scott Fitzgerald
Arduino Starter Kit Multi-language — Arduino Official Store
This example code is part of the public domain.
// include the Servo library
#include <Servo.h>
Servo myServo; // create a servo object
int const potPin = A0; // analog pin used to connect the potentiometer
int potVal; // variable to read the value from the analog pin
int angle; // variable to hold the angle for the servo motor
int pos = 0;
myServo.attach(9); // attaches the servo on pin 9 to the servo object
Serial.begin(9600); // open a serial connection to your computer
potVal = analogRead(potPin); // read the value of the potentiometer
// print out the value to the Serial Monitor
Serial.print("potValue: ");
Serial.print(potVal);
// scale the numbers from the pot
angle = map(potVal, 0, 1023, 0, 179);
// print out the angle for the servo motor
Serial.print(", angle: ");
Serial.println(angle);
// set the servo position
myServo.write(angle);
// wait for the servo to get there
delay(15);
// back to angle 0
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
myServo.write(0);
Thank you for the reply Paul, but now my servomotor can't be controlled with the potmeter.
// back to angele 0
myServo.write(0);
Hello kazvr013
Take some time and describe the desired functionality of the sketch in simple words and this very simple and short form, including all dependencies between inputs and outputs.
Дайте миру шанс!
re-edit your first posting.
Your code should be formatted as a code-section.
This manual explains how to do this
best regards Stefan
I'm going to take a guess that once you adjust the pot and the servo moves to it's set position and back to 0 that you do not want the servo to move again unless the pot value (and subsequently the angle) changes.
In order to accomplish this I would recommend the following:
  1. Save the last value of angle
  2. If the the current angle is different than the last angle then move the servo to it's set position and back to 0; otherwise do nothing.
