Set state of 8 pins from bits in a byte
On an Arduino, I’m lighting up 8 LEDs with patterns. I have the patterns stored as binary values in an array. I’m stuck with how to read each bit in a pattern and assign to a pin.
I think problem is at the “stuck here” below.
This must be answered already somewhere but I can’t find the right search terms to find it. My hits are similar but much more complex scenarios. Thanks.
byte patterns[3] = {0b10101010, 0b11111111, 0b11011000};
byte pins[8] = {2,3,4,5,6,7,8,9};
// set all led pins to outputs
  for (byte currentPin = 0; currentPin <8; currentPin++){
    pinMode(pins[currentPin], OUTPUT);
  } // for
} // setup
// go through each pattern
  for(byte currentPattern=0; currentPattern<3;currentPattern++)
// use bits of current pattern to set pins
      /* stuck here:
      need to read each bit from the current pattern
      and assign to each pin
} // loop
The bitRead() and bitWrite() functions may be useful.
How about this? I used sizeof instead of magic numbers so you can change the number of pins, patterns or bits easier.
byte pins[8] = {2, 3, 4, 5, 6, 7, 8, 9};
   for (byte currentPin = 0; currentPin < sizeof(pins); currentPin++)
   } // for
} // setup
   for (byte currentPattern = 0; currentPattern < sizeof(patterns); currentPattern++)
      for(byte n = 0; n < sizeof(pins); n++)
        digitalWrite(pins[n], bitRead(patterns[currentPattern], n));
} // loop
Hi @JohnKauffman
try this code:
  } // for
} // setup
     PORTD = patterns[currentPattern] >> 2;       // sets digital 2-7 pins
     PORTB = patterns[currentPattern] << 6;       // sets digital 8 & 9 pins
      /* stuck here:
} // loop
  byte pattern = patterns[currentPattern];
  for (byte currentPin = 0; currentPin < 8; currentPin++)
    byte bitMask = 0x80 >> currentPin; // Bits left to right
    digitalWrite(pins[currentPin], pattern & bitMask);
G'Fungus:
Wo-Hoo.
Took your advice at looking into bitRead(). Half hour later, got it all working. And is same as your later post.
Much thanks for starting with just tip so I could work on it.
ruilviana:
I got it working with bitRead(). Now will work on understanding your solution. I have always wanted to learn about bit shifting. Thanks.
JohnWasser:
Got it working with bitRead(). Now it looks like it is time for me to get down to understanding masking.
Thanks.
For future searchers, here is my completed code.
byte patterns[] = {0b11000000, 0b10100000, 0b10010000};
byte lenPatterns = 3;
byte index =0; // when read bits: pin index *and* bit index
  for (byte currentPin=0; currentPin<8; currentPin++){
  } // for
  for(currentPattern = 0;currentPattern<lenPatterns;currentPattern++){
    for(index=0;index<8;index++){
        Serial.print( bitRead( patterns[currentPattern], index), BIN);
        digitalWrite( pins[index], bitRead( patterns[currentPattern], index));
void loop() {} // loop
