'setTime' was not declared in this scope
Hi, after updating Arduino to 1.6.10 when compiling the same code I obtain the error
How I can fix it?
How I can fix it?
Don't call functions that aren't defined.
Post your code (ALL of it) and the EXACT error message(s).
The code is too big to paste all, so I extract the block when the error is found:
#include <SimpleTimer.h>
#include <Time.h>
#include <Wire.h>
#include "RTClib.h"
#include <avr/wdt.h>
RTC_DS1307 DS1307;
void setup () {
 Wire.begin();
  if (! DS1307.begin()) {
    debugMillis(F("Couldn't find RTC!"), "", false, false);
    debugMillis(F("RTC found."), "", false, false);
    DateTime cTime = DS1307.now();
    setTime(cTime.hour(), cTime.minute(), cTime.second(), cTime.day(), cTime.month(), cTime.year());
    debugMillis("Time synced with RTC: ", stringTime(), false, false);
... and the error is ...
C:\Users\Igor\Documents\Arduino\myReef2_Mega\myReef2_Mega.ino: In function 'void setup()':
myReef2_Mega:769: error: 'setTime' was not declared in this scope
Nope, I'm trying to call the class Time.h
Before upgrading to Arduino 1.6.10 and the relative libraries all works good... uhm...
The Time library works better if you #include <TimeLib.h> instead of <Time.h>.
(Time.h contains just that one #include.)
In your time library folder there should be three files
Time.cpp
Time.h
TimeLib.h
oqibidipo:
Yesssss!!! This was the problem! Thankssss!
:confused: me to i have the same erreur i do not know to do
I have some simmilar problems , could you help me please?
the message error is as follows
Arduino:1.8.1 (Windows 7), Tarjeta:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\MAO\Documents\Arduino\ejemplo_timer\ejemplo_timer.ino:6:0:
C:\Users\MAO\Documents\Arduino\libraries\TimeAlarms/TimeAlarms.h:71:31: error: 'timeDayOfWeek_t' does not name a type
AlarmID_t alarmRepeat(const timeDayOfWeek_t DOW, const int H, const int M, const int S, OnTick_t onTickHandler); // as above, with day of week
C:\Users\MAO\Documents\Arduino\libraries\TimeAlarms/TimeAlarms.h:75:29: error: 'timeDayOfWeek_t' does not name a type
AlarmID_t alarmOnce(const timeDayOfWeek_t DOW, const int H, const int M, const int S, OnTick_t onTickHandler); // as above, with day of week
C:\Users\MAO\Documents\Arduino\ejemplo_timer\ejemplo_timer.ino: In function 'void setup()':
ejemplo_timer:23: error: 'setTime' was not declared in this scope
setTime(now.hour(), now.minute(), now.second(), now.month(), now.day(), now.year());
C:\Users\MAO\Documents\Arduino\ejemplo_timer\ejemplo_timer.ino: In function 'void digitalClockDisplay()':
ejemplo_timer:72: error: 'hour' was not declared in this scope
Serial.print(hour());
ejemplo_timer:73: error: 'minute' was not declared in this scope
printDigits(minute());
ejemplo_timer:74: error: 'second' was not declared in this scope
printDigits(second());
Se encontraron múltiples librerías para "Wire.h"
Usado: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
No usado: C:\Users\MAO\Documents\Arduino\libraries\Wire
exit status 1
Would it be stating the bleedin' obvious to point out that you haven't posted your code?
It would?
Too bad.
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\soe wonna\Downloads\arduinosketch\arduinosketch.ino: In function 'void loop()':
arduinosketch:170: error: 'now' was not declared in this scope
startTime = now();
arduinosketch:281: error: 'now' was not declared in this scope
currentTime = setupTime - (now() - startTime);
arduinosketch:337: error: 'hour' was not declared in this scope
if(hour(currentTime) < 10) lcd.print("0");
arduinosketch:338: error: 'hour' was not declared in this scope
lcd.print(hour(currentTime));
arduinosketch:340: error: 'minute' was not declared in this scope
if(minute(currentTime) < 10) lcd.print("0");
arduinosketch:341: error: 'minute' was not declared in this scope
lcd.print(minute(currentTime));
arduinosketch:343: error: 'second' was not declared in this scope
if(second(currentTime) < 10) lcd.print("0");
arduinosketch:344: error: 'second' was not declared in this scope
lcd.print(second(currentTime));
Multiple libraries were found for "LiquidCrystal.h"
Used: C:\Program Files\Arduino\libraries\LiquidCrystal
Not used: C:\Users\soe wonna\Documents\Arduino\libraries\NewliquidCrystal
exit status 1
option enabled in File -> Preferences.
@wonna: see reply #11
i have a similar problem, i have download the #include <TIMElib.h>, but i still get the error message that 'currentTIME' can not be used as a function.
Fonkwe:
I expect you're doing something wrong in the code that you haven't shown us.
Steve
