Hi-
You need to sync with the RTC.
This code uses the alarm library AND an RTC.
Jim
* TimeAlarmExample.pde
* This example calls alarm functions at 8:30 am and at 5:45 pm (17:45)
* and simulates turning lights on at night and off in the morning
* A weekly timer is set for Saturdays at 8:30:30
* A timer is called every 15 seconds
* Another timer is called once only after 10 seconds
* System time now set from RTC, jim august 2014
* remember to set the rtc first...
* added wire and ds1307rtc libraries
#include <Time.h>
#include <TimeAlarms.h>
#include <Wire.h> //added jim ************************
#include <DS1307RTC.h> //added jim ***************************
Serial.println("In setup...."); //added jim *****************
using rtc, sync system time to rtc
setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011 //old way *****************
// following lines added to set time from rtc, took from timeRtcSet example, added jim *****************
setSyncProvider(RTC.get); // the function to get the time from the RTC
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
// end of setting the time ******************************
// create the alarms
Alarm.alarmRepeat(11, 30, 30,led13OFF);
Alarm.alarmRepeat(11, 30, 00,led13ON);
//Alarm.alarmRepeat(11,16,0, MorningAlarm);
Alarm.alarmRepeat(10, 35,45, MorningAlarm);
Alarm.alarmRepeat(10,36,0, MorningAlarm);
Alarm.alarmRepeat(10, 36,30, MorningAlarm);
Alarm.alarmRepeat(10,37,0, MorningAlarm);
Alarm.alarmRepeat(10, 15,30, MorningAlarm);
Alarm.alarmRepeat(10,16,0, MorningAlarm);
Alarm.alarmRepeat(10,16,30, MorningAlarm);
Alarm.alarmRepeat(10,17,0, MorningAlarm);
Alarm.alarmRepeat(10, 17,30, MorningAlarm);
Alarm.alarmRepeat(17,45,0,EveningAlarm); // 5:45pm every day
Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm); // 8:30:30 every Saturday
//Alarm.timerRepeat(15, Repeats); // timer for every 15 seconds
//Alarm.timerOnce(10, OnceOnly); // called once after 10 seconds
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Serial.print("Turning pin 13 LED off at ");
digitalClockDisplay();
Serial.println("Ending setup...."); //added jim *****************
void loop(){
Alarm.delay(1000);
// functions to be called when an alarm triggers:
void led13ON(){
//Serial.print("Turning pin 13 LED on at ");
//digitalClockDisplay();
digitalWrite(13, HIGH);
void led13OFF(){
//Serial.print("Turning pin 13 LED off at ");
void MorningAlarm(){
Serial.println("Alarm: - turn lights off Jimbo");
void EveningAlarm(){
Serial.println("Alarm: - turn lights on");
void WeeklyAlarm(){
Serial.println("Alarm: - its Monday Morning");
void ExplicitAlarm(){
Serial.println("Alarm: - this triggers only at the given date and time");
void Repeats(){
Serial.println("15 second timer");
void OnceOnly(){
Serial.println("This timer only triggers once");
void digitalClockDisplay()
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
