I have built a timing system using Sharp IR Distance sensors that are used to give me the split time and finish time but I am running into an issue with the range on the sensors from reading when the person passes the sensor. The one I am using is Sharp IR Distance sensor 20-150cm GP2Y0A02YK0F.
when it is in the waiting position it is in a LOW state but when a person passes by it it will register a HIGH stage recording the millis of that moment.
the issue I am running into is that if the person is more then 30-35 cm away from the sensor it won't work.... any closer and it works just fine. the range of the sensor should be up to 150cm.
with the documentation of the Sharp sensor it looks like there is a big change in voltage from 0- about 40cm and then it seems to level out a little and a little less drastic with the changes and I am thinking that this may be where the problem lies.
I would like a way to make this work to at least 60cm. I do understand that there could be an option to use a system where a break beam system with a laser but that really won't be feasible for the application I have because there is a fair bit of movement and it would be impossible to keep the laser aligned.
The add indicates that it has an analog output that varies from 2.8V at 15cm to 0.4V at 150cm with a supply voltage between 4.5. You are talking about low and high states, that is not typical of an analog signal. Try using the analog input for your readings. Also since it is a retroreflective sensor the target (what your bouncing the IR signal off of) has a big impact on the range.
